Product
TP LINK WLAN-Antenna 2.4GHz 14dBi Outdoor Yagi SMA
Quicklinx: 898JWS00 Mfr#: TL-ANT2414A
Type: Antennas
4 in stock
£47.90 ex VAT
£57.48 inc VAT
Standard delivery Delivered within 3-5 working days
  • 14dBi directional operation boosts your signal to a further distance in a specific direction.
  • Features 100cm CFD-200 low loss cable for flexible deployment.
  • RP-SMA Male connector, works with most of access points / wireless routers.
  • Provides easy installation mounting kits.
TP-Link TL-ANT2414A - antenna
Antenna
24 cm x 24 cm x 4 cm
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, wall-mountable, pole mount
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.5 GHz
Gain
14 dBi
Directivity
Directional
Plug and Play, FCC, RoHS
Antenna
24 cm
24 cm
4 cm
Cable Length
1 m
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.5 GHz
Gain
14 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
1.92:1
Horizontal Beamwidth
30°
Vertical Beamwidth
30°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA male
-10 °C
60 °C
10 - 90%
Type: Antennas
Brand: TP LINK
Price Range Ex VAT: 0 - 50
