- TP-Link TL-ANT2414B - antenna
- Product Type
- Antenna
- 24 cm x 24 cm x 4 cm
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, wall-mountable, pole mount
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 14 dBi
- Directivity
- Directional
- FCC, RoHS
- Product Type
- Antenna
- 24 cm
- 24 cm
- 4 cm
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 b/g
- Frequency Range
- 2.4 - 2.5 GHz
- Gain
- 14 dBi
- Directivity
- Directional
- Voltage Standing Wave Ratio (VSWR)
- 1.92:1
- Horizontal Beamwidth
- 60°
- Vertical Beamwidth
- 76°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x N-Series connector female
- FCC, RoHS
- -10 °C
- 60 °C
- 10 - 90%
