Print servers give businesses the ability to streamline their printing requirements by taking commonly used printers, multifunction products, and all-in-ones, and connecting them to a network. This allows for more efficient printer management and more reliable performance of connected devices that require less maintenance thereby making printing problems, a less common occurrence.
TL-WPS510U is featuring functions that make users lives easier. The TL-WPS510U has come to a new level in technological excellence. With these functions and the addition of wireless capabilities, the TL-WPS510U gives your printers the power of flight!
- TP-Link TL-WPS510U - print server - USB 2.0
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 6.5 cm x 4 cm x 1.9 cm
- 45 g
- Data Link Protocol
- 802.11b/g
- Data Transfer Rate
- 54 Mbps
- TCP/IP, LPR/LPD
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows XP, Apple MacOS X 10.2 or later, Microsoft Windows Vista, Microsoft Windows 2003
- Print server
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 54 Mbps
- TCP/IP, LPR/LPD
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz
- Status Indicators
- Power, link/activity
- DHCP support, firmware upgradable
Aerial
- Antenna
- External detachable
- Antenna Qty
- 1
- Directivity
- Omni-directional
- Gain Level
- 1.8 dBi
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- FCC
- Power Device
- Power adapter - external
- OS Required
- 6.5 cm
- 4 cm
- 1.9 cm
- 45 g
- 0 °C
- 50 °C
- 0 - 70%
