Product
TP LINK Wireless Print Server USB2.0
Quicklinx: 77S4WS00 Mfr#: TL-WPS510U
Wired / Wireless: Wireless
Speed: 54Mbps
Protocol: IEEE 802.11b, IEEE 802.11g
Form Factor: External
Interface: USB 2.0
£40.08 ex VAT
£48.09 inc VAT
Print servers give businesses the ability to streamline their printing requirements by taking commonly used printers, multifunction products, and all-in-ones, and connecting them to a network. This allows for more efficient printer management and more reliable performance of connected devices that require less maintenance thereby making printing problems, a less common occurrence.
TL-WPS510U is featuring functions that make users lives easier. The TL-WPS510U has come to a new level in technological excellence. With these functions and the addition of wireless capabilities, the TL-WPS510U gives your printers the power of flight!
TP-Link TL-WPS510U - print server
Print server
External
Interface (Bus) Type
USB 2.0
6.5 cm x 4 cm x 1.9 cm
45 g
802.11b, 802.11g
Data Transfer Rate
54 Mbps
Network / Transport Protocol
TCP/IP, LPR/LPD
Frequency Band
2.4 GHz
Linux, Microsoft Windows 2000, Microsoft Windows XP, Apple MacOS X 10.2 or later, Microsoft Windows Vista, Microsoft Windows 2003
Print server
External
USB 2.0
Wireless
802.11b, 802.11g
Data Transfer Rate
54 Mbps
TCP/IP, LPR/LPD
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz
Status Indicators
Power, link/activity
DHCP support, firmware upgradable
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
1.8 dBi
1 x USB 2.0 - 4 pin USB Type B
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC
Power adapter - external
6.5 cm
4 cm
1.9 cm
45 g
50 °C
0 - 70%
77S4 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
77S4 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.51
77S4 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.76
77S4 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
77S4 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.73
77S4 C2G USB Superbooster Extender Kit In Stock £37.81
77S4 C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.38
77S4 C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Speed: 54Mbps
Protocol: IEEE 802.11g
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Brand: TP LINK
Price Range Ex VAT: 0 - 50
