TP LINK WBS210 2.4GHz 300Mbps Outdoor Wireless Base Station POE
Quicklinx: CM9YWS00 Mfr#: WBS210
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: Mac, PC
  • IEEE 802.11n
£44.41 ex VAT
£53.29 inc VAT
Outdoor 2.4GHz 300Mbps Wireless Base Station up to 30dBm 802.11b/g/n 2 ext. antenna interfaces 10/100Mbps 110/100/1000Mbps LAN Weatherproof Passive PoE
TP-Link WBS210 - radio access point
Radio access point
External - outdoor
1 x Qualcomm MIPS 74KC 560 MHz
RAM
64 MB
Flash Memory
8 MB
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
7.5 cm x 3.2 cm x 18.9 cm
Radio access point
Ruggedized Design
Outdoor
7.5 cm
3.2 cm
18.9 cm
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP
Remote Management Protocol
SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Repeating mode, ALG support, manageable, DFS support, Wireless Distribution System (WDS) support, Multiple SSID support, wireless bridge mode, bandwidth control, Wireless Client Mode, pole mountable, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, 15KV ESD Protector
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
1 x 1000Base-T (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 2 x aerial - RP-SMA
FCC, RoHS, IP65
PoE
Power injector
Software Included
Drivers & Utilities
-30 °C
70 °C
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: TP LINK
Price Range Ex VAT: 0 - 50
