TP LINK WBS210 2.4GHz 300Mbps Outdoor Wireless Base Station POE
Quicklinx: CM9YWS00 Mfr#: WBS210
  • IEEE 802.11n
Outdoor 2.4GHz 300Mbps Wireless Base Station up to 30dBm 802.11b/g/n 2 ext. antenna interfaces 10/100Mbps 110/100/1000Mbps LAN Weatherproof Passive PoE
  • TP-LINK MAXtream TDMA technology
    As network scale increases, wireless competition and collisions among CPEs will be so fierce that the real throughput of the network will drop, resulting in a serious impact on end-user experience, to mitigate these effects, TP-LINK's Pharos series uses MAXtream TDMA technology.
  • Pharos Control - centralized management system
    Pharos also comes equipped with centralized management software that helps users easily manage all the devices in their network from a single PC - Pharos Control. Functions like device discovery, status monitoring, firmware upgrading, and network maintenance can be managed using Pharos Control.
  • PharOS
    User-friendly web-based management system allows professionals to do more specific configurations.
TP-Link WBS210 - radio access point - Wi-Fi
Radio access point
External - outdoor
1 x Qualcomm MIPS 74KC 560 MHz
RAM
64 MB
Flash Memory
8 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
7.5 cm x 3.2 cm x 18.9 cm
Radio access point
Ruggedized Design
Outdoor
7.5 cm
3.2 cm
18.9 cm
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP
Remote Management Protocol
SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Repeating mode, ALG support, manageable, DFS support, Wireless Distribution System (WDS) support, Multiple SSID support, wireless bridge mode, bandwidth control, Wireless Client Mode, pole mountable, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, 15KV ESD Protector
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
1 x 1000Base-T (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 2 x aerial - RP-SMA
FCC, RoHS, IP65
PoE
Power injector
Software Included
Drivers & Utilities
-30 °C
70 °C
10 - 90% (non-condensing)
