Product
TP LINK USB 3.0 4-Port Portable Hub
Quicklinx: BRPVWS00 Mfr#: UH400
Type: USB Hub
Ports: 4
43 in stock
£12.95 ex VAT
£15.54 inc VAT
The UH400 USB Hub supports all USB devices including USB drives, mice, printers or any other USB device you want to run simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than the USB 2.0 standard. Equipped with USB 3.0 ports, UH400 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0. UH400 adds 4 additional USB ports to your PC, making it unnecessary to switch between devices. Compact design with a retractable cable makes it an ideal USB HUB on the go. UH400's multiple protections avoid any potential harm to your connected devices no matter you're transferring data or charging devices.
TP-Link UH400 - hub - 4 ports
Hub - 4 ports
Ports
4 x SuperSpeed USB 3.0
USB 2.0, USB 3.0
7.1 cm x 7.1 cm x 1.66 cm
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Hub - 4 ports
Enclosure Type
Desktop
Ports
USB 2.0, USB 3.0
1 x VIA VL812
4 x USB 3.0 Type A
7.1 cm
7.1 cm
1.66 cm
Type: USB Hub
Ports: 4
Brand: TP LINK
Price Range Ex VAT: 0 - 50
