TP LINK TP-Link N600 Wirlss Gigabit Access Point
Quicklinx: BGG6WS00 Mfr#: EAP220
  • IEEE 802.11n
The EAP's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations.
EAP series APs support Power over Ethernet (PoE) to make deployment effortless and flexible. The free controller software allows administrators to easy manage up to hundreds of EAPs through a single IP to like an Access Controller.
  • Flexible placement
    The EAP's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations. EAP series APs support Power over Ethernet (PoE) to make deployment effortless and flexible.
  • Business class wireless
    Gigabit Ethernet port ensures high-speed Internet access.
  • Efficient guest authentication captive portal
    Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password.
  • Designed for business performance
    EAP220 is specially designed for the high-density, most demanding business environments, including schools, hotels, and enterprises.
  • Load balance
    Load balance ensures large numbers of users have smooth network experiences in large business networks.
  • Dustproof design
    Prevents dust from dropping onto the PCB through bypass louver, which ensures long-term, unhindered operation.
  • Quality of Service (QoS)
    It prioritizes data, voice, and video applications to ensure time-sensitive traffic takes priority over all other traffic.
TP-Link Omada EAP220 - radio access point - Wi-Fi
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Microsoft Windows Vista / XP / 7 / 8
Power Over Ethernet (PoE) Supported
PoE
18 cm x 18 cm x 4.75 cm
Radio access point
18 cm
18 cm
4.75 cm
External
Wireless
Data Transfer Rate
600 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, CLI
Frequency Band
2.4 GHz, 5 GHz
Load balancing, VLAN support, Syslog support, manageable, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
Gain Level
4 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x management (RS-232) - RJ-45
UL 2043, FCC, RoHS
PoE
External power adapter
9.6 Watt
Software Included
Drivers & Utilities
10 - 90% (non-condensing)
BGG6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
