TP LINK TP-LINK Archer C50 - Wireless router - 4-port switch - 802.11a/b/g/n/ac - Dual Band
Quicklinx: BLYKWS00 Mfr#: ARCHER C50
  • IEEE 802.11n
TP-LINK's Archer C50 comes with the next generation Wi-Fi standard - 802.11ac, 3 times faster than wireless N speeds and delivering a combined wireless data transfer rate of up to 1.2 Gbps.
With 300Mbps over the 2.4GHz band and 867Mbps wireless speeds over the crystal clear 5GHz band, the Archer C50 is the superior choice for seamless HD streaming, online gaming and other bandwidth-intensive tasks.
  • 1.2 Gbps dual band connections for lag-free work and entertainment
    The Archer C50 operates over both the 2.4GHz and 5GHz bands, ensuring amazing wireless performance. Simultaneous Dual Band offers you the flexibility of two dedicated networks - with multiple times the bandwidth for your needs. Simple tasks like sending e-mails or web browsing can be handled by the 2.4GHz band while bandwidth intensive tasks like online gaming or HD video streaming can be processed by the 5GHz band - all at the same time.
  • 2 external antennas for optimal coverage
    With 2 external antennas combined with high quality antenna technology, you can maintain high speeds across greater distances. This provides you with optimal wireless coverage and reliability from anywhere in your large home or office.
  • USB port for storage and sharing
    With USB 2.0 port, you can share a printer locally and files & media with networked devices or remotely via FTP server.
  • Guest network
    Guest network access provides secure Wi-Fi access for guests sharing your home or office network.
  • Parental control
    Parental control allows parents or administrators to establish restricted access policies for children or staff.
  • IPv6 supported
    Archer C50 supports IPv6, the next generation of Internet protocol, helping you to future proof your network.
  • Tether APP
    TP-LINK Tether provides the easiest way to access and manage your router with your iOS and Android devices.
TP-Link Archer C50 - wireless router - 802.11a/b/g/n/ac - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
DoS attack prevention, IPv6 support, Wireless Distribution System (WDS) support, parental control, IP address filtering, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, reset button, bandwidth control, IPv4 support, port triggering, Stateful Packet Inspection Firewall (SPIF), DHCP client
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
23 cm x 14.4 cm x 3.5 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7, Windows 8 / 8.1 / 10
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.2 Gbps
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
Wi-Fi AC Rating
AC1200
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, RoHS
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
4
Directivity
Omni-directional
External power adapter
1 x network cable
Software Included
Drivers & Utilities
23 cm
14.4 cm
3.5 cm
10 - 90% (non-condensing)
Network Adaptors (2)
Expand your network
BLYK C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.95
BLYK C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.02
Other bundles (6)
BLYK C2G 2m USB 2.0 A/B Cable - Black In Stock £3.82
BLYK C2G 5m USB 2.0 A/B Cable - Black In Stock £4.99
BLYK C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.37
BLYK C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.49
BLYK C2G USB Superbooster Extender Kit In Stock £37.24
BLYK C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
