TP LINK TL-SG105E 5-Port Gigabit Easy Smart Switch
Quicklinx: 9T95WS00 Mfr#: TL-SG105E
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
10 in stock
£21.20 ex VAT
£25.44 inc VAT
The TL-SG105E 5-Port Gigabit Easy Smart switch is an ideal upgrade from an unmanaged switch, designed for Small and Medium Business networks that require simple network management.
Network administrators can effectively monitor traffic via Port Mirroring, Loop Prevention and Cable Diagnostics features. To optimize traffic on your business network, TL-SG105E offers both port and tag based QoS to keep latency-sensitive traffic moving smoothly and jitter-free. Additionally, port-based, tag-based and MTU VLAN can improve security and meet more network segmentation requirements. Moreover, with its innovative energy-efficient technology, the TL-SG105E can save up to 75% of power consumption, making it an eco-friendly solution for your business network.
Simple & Effective Management
TP-LINK's Gigabit Easy Smart switch, TL-SG105E offers network monitoring for users to observe traffic behavior. With Port Mirroring, Loop Prevention and Cable Diagnostics features, TL-SG105E can identify and even locate connection problems on your business network. Moreover, administrators can designate the priority of the traffic based on Port Priority and 802.1P Priority, to ensure that voice and video are always clear, smooth and lag-free. Additionally, to improve security and network performance, TL-SG105E supports MTU VLAN, port-based VLAN and 802.1Q-based VLAN functions. TL-SG105E is an upgrade from the plug-and-play Unmanaged Switch, delivering great value while empowering your network and similarly delivering great value to the end user.
Go Green with Your Ethernet
You now have the choice to go green when upgrading to a gigabit network! This new generation of TL-SG105E 5-Port Gigabit Easy Smart Switch features the latest energy-efficient technologies that can greatly expand your network's capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
Power down Idle Ports
When a computer or network equipment is off, the corresponding port of a traditional switch will continue to consume considerable amounts of power. The TL-SG105E can automatically detect the link status of each port and reduce the power consumption of ports that are idle.
Power Budget According to Cable Length
Ideally, shorter cables would use less power with less power degradation over their length; this is not the case with most devices as they will use the same amount of power across the cable regardless of whether it is 10 or 50 meters in length. The TL-SG105E analyzes the length of the Ethernet cable connected and adjusts the power usage accordingly, rather than keeping the power consumption in a conventional solution.
Ease of Use
TL-SG105E is easy to use and manage. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance. Its compact size makes it ideal for desktops with limited space while also being Rack-mountable, convenient and safe. Dynamic LED lights provide real-time work status display and basic fault diagnosis.
  • Simple and effective management
    TP-LINK's Gigabit Easy Smart switch, TL-SG105E offers network monitoring for users to observe traffic behavior. With port mirroring, loop prevention and cable diagnostics features, TL-SG105E can identify and even locate connection problems on your business network. Moreover, administrators can designate the priority of the traffic based on Port Priority and 802.1P Priority, to ensure that voice and video are always clear, smooth and lag-free. Additionally, to improve security and network performance, TL-SG105E supports MTU VLAN, port-based VLAN and 802.1Q-based VLAN functions. TL-SG105E is an upgrade from the Plug-and-Play Unmanaged Switch, delivering great value while empowering your network and similarly delivering great value to the end user.
  • Go green with your Ethernet
    You now have the choice to go green when upgrading to a gigabit network. The TL-SG105E 5-Port Gigabit Easy Smart switch features the energy-efficient technologies that can greatly expand your network's capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
  • Power down idle ports
  • Power budget according to cable length
  • Ease of use
TP-Link Easy Smart TL-SG105E - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Forwarding performance: 7.4 Mpps
Virtual interfaces (VLANs): 32
MAC Address Table Size
8K entries
Jumbo Frame Support
16KB
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Quality of Service (QoS), Cable Diagnostics Function, fanless, loop prevention, Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
10 cm x 9.8 cm x 2.5 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Vista / XP / 7 / 8
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
16KB
Status Indicators
Port status, power
5 x 1000Base-T RJ-45
External power adapter
FCC, RoHS
Software Included
Drivers & Utilities
10 cm
9.8 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
9T95 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9T95 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
9T95 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
Ports: 5
Managed: Yes
POE: No
Brand: TP LINK
Price Range Ex VAT: 0 - 50
