Your basket is empty
TP LINK TL-SG1008P 8 port Gigabit POE switch & TL-SG105
Quicklinx: BLYYWS00 Mfr#: TL-SG1008P+TL-SG105FOC?BDL
TL-SG1008P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-LINK TL-SG1008P 8-port gigabit desktop switch with 4-port PoE is a great selection for expanding your home or office network.
TP-LINK TL-SG1008P - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
1K entries
Flow control, full duplex capability, power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
(50/60 Hz)
17.1 cm x 9.8 cm x 2.7 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
1K entries
Status Indicators
Power, link/activity
4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
External power adapter
(50/60 Hz)
FCC
17.1 cm
9.8 cm
2.7 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
