TL-SG1008P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-LINK TL-SG1008P 8-port gigabit desktop switch with 4-port PoE is a great selection for expanding your home or office network.
Overload arrangement
TL-SG1008P has the priority function which will help protect the system when the system power is overloaded. -
Easy to use
- TP-Link TL-SG1008P - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 4 x 10/100/1000 (PoE) + 4 x 10/100/1000
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 1K entries
- Flow control, full duplex capability, power over Ethernet (PoE), auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
- IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
- Power
- (50/60 Hz)
- 17.1 cm x 9.8 cm x 2.7 cm
- Enclosure Type
- Desktop
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- 1K entries
- Status Indicators
- Power, link/activity
- 4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
- Power Device
- External power adapter
- Voltage Required
- (50/60 Hz)
- FCC
- 17.1 cm
- 9.8 cm
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
