TP LINK TL-R470T+ Load Balance Broadband Router
Quicklinx: 9Q3WWS00 Mfr#: TL-R470T+
Type: Router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet
Speed: [N/A]
Rackmount or External: External
27 in stock
£29.26 ex VAT
£35.11 inc VAT
The TL-R470T+ load balance broadband router is a wise choice for small businesses. It brings you high return on investment. Featuring three changeable WAN/LAN ports, TL-R470T+ supports up to 4 WAN ports, which can satisfy various Internet access requirements through one device. TL-R470T+ integrates multiple load balancing strategies, advanced QoS, and strong firewall to provide you with consistent network uptime and reliable Ethernet connectivity. Moreover, it is easy to manage the TL-R470T+ via a web-based utility, which makes building and managing your network more convenient.
The TL-R470T+ features three changeable ports that can be set to either LAN or WAN, allowing the router to support up to four WAN ports to satisfy various Internet access requirements through one device. The router also has an integrated smart load balancing function which automatically selects the most efficient line according to load and bandwidth requirements, providing users with consistent network uptime and reliable Ethernet connectivity.
Abundant Security Features
For defense against external threats, TL-R470T+ can automatically detect and block Denial of service (DoS) attacks such as TCP/UDP/ICMP Flooding, Ping of Death and other related threats. Moreover, this router provides IP/MAC/URL/WEB ­filtering functions, which forcefully prevent attacks from intruders and viruses. For applications such as FTP, H.323, SIP, IPsec and PPTP which are not well compatible with NAT, TL-R470T+ offers administrators one-click enable of ALG choices corresponding to the above five applications.
Efficient Access Management
By setting up a PPPoE Server to allocate PPPoE accounts to private network users, the router only allows users with legal accounts that have passed authentication to access the Internet. With IP-based Bandwidth Control, the router is capable of confining bandwidth usage of certain PPPoE accounts. Moreover, the E-Bulletin function is able to release a bulletin in the form of webpage to certain user groups periodically, which notifies the users about the expiration date of the PPPoE account. With the above features, the router will prioritize different users in surfer jurisdictions for more efficient management.
Safety-Minded Enterprise Investments
Professional lightning protection technology is designed to prevent electrical surges from penetrating the interior of the device. This router is designed to prevent lightning damage of up to 4KV in the well-grounded connection conditions. This feature ensures that networking infrastructure investments remain as safe as possible from lightning attacks.
Key Features
Three Changeable WAN/LAN Ports
  • Superior Performance and High Stability
    The router features a network dedicated processor, clocked at 400MHz for powerful processing performance, an internal power supply to allow for long term operation stability, and professional lightning protection design keeps your investments as safe as possible.
  • Three Changeable LAN/WAN Ports
    The TL-R470T+ features three changeable ports that can be set to either LAN or WAN, allowing the router to support up to four WAN ports to satisfy various Internet access requirements through one device. The router also has an integrated smart load balancing function which automatically selects the most efficient line according to load and bandwidth requirements, providing users with consistent network uptime and reliable Ethernet connectivity. By the factory default, TL-R470T+ is set to work in the dual WAN ports mode: port 1 and port 2 are working as WAN ports, while port 3~5 are LAN ports.
  • Management for a Fluid Networking Experience
    Integrating multiple load balancing strategies, IP and port based bandwidth control, session limit, domain filtering, and IP/MAC address filtering, the TL-R470T+ provides users with a fluid network experience, without lag and connection drops.
  • Easy to Install and Use
    With user-friendly web-based management, remote management and configuration backup & restore functions, the TL-R470T+ provides many comprehensive features that are easy to deploy and maintain, especially for businesses lacking professional IT staff.
TP-Link TL-R470T+ - router
Router
WAN Ports Qty
4
Network / Transport Protocol
TCP/IP, PPTP, L2TP, ICMP/IP, PPPoE, DHCP, DNS, DDNS
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, load balancing, DoS attack prevention, port mirroring, MAC address filtering, VPN passthrough, parental control, IP address filtering, domain blocking, SNTP support, Quality of Service (QoS), virtual server support, DHCP server, static IP mode, UPnP Media Server, bandwidth control, port triggering, dynamic IP mode, time based access control
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
20.9 cm x 12.6 cm x 2.6 cm
Router
Wired
HTTP
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, FCC, RoHS
400 MHz
WAN / LAN: 3 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
1 x network cable
Software Included
Drivers & Utilities
20.9 cm
12.6 cm
2.6 cm
10 - 90% (non-condensing)
9Q3W C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9Q3W C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
9Q3W C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.07
9Q3W C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Speed: [N/A]
Brand: TP LINK
Price Range Ex VAT: 0 - 50
