TL-PB2600 is a stand-alone power solution that ensures you never lose touch with your world on the move. TL-PB2600 relieves you from the endless anxiety of energy crisis.
Never worry running out of power
TL-PB2600 is a stand-alone power solution that ensures you never lose touch with your world on the move. TL-PB2600 relieves you from the endless anxiety of energy crisis. -
Ultra mini
The original exquisite lipstick design ensures a fit in everywhere. It weighs like nothing. You barely sense its existing when you carry it in your pocket. -
Reliable power
TL-PB2600 is an ultra compact power bank with superior quality that comes equipped with 6 in 1 complete protection against damage caused by: short circuit, over-voltage, over-current,over-charge, over-discharge, and over-heating. -
High energy efficiency rate
Powered by TP-LINK's world class circuitry and advanced energy technologies, TL-PB2600 signifi-cantly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. -
Increased compatibility
Compatible with iPhone, iPad, Android smartphones and most 5V input digital devices.
- TP-Link TL-PB2600 power bank - USB
- Product Type
- Power bank
- 2.56 cm x 2.56 cm x 9.35 cm
- 68 g
- Output Connector Type
- USB - on cable: Micro-USB
- Max Electric Current
- 2.4 A
- Battery
- 2600 mAh
- Cables
- Micro-USB cable
- Product Type
- Power bank
- 2.56 cm
- 2.56 cm
- 9.35 cm
- 68 g
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.4 A
- LED indicator
- Voltage Provided
- 5 V
- Capacity
- 2600 mAh
- Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
- Cables Included
- Micro-USB cable
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
