Your basket is empty
TP LINK TL-PB2600 2600mAh Pocket-Sized Power Bank 5V USB
Quicklinx: BRPYWS00 Mfr#: TL-PB2600
TL-PB2600 is a stand-alone power solution that ensures you never lose touch with your world on the move. TL-PB2600 relieves you from the endless anxiety of energy crisis.
TP-Link TL-PB2600 - power bank
Power bank
2.56 cm x 2.56 cm x 9.35 cm
68 g
Output Connector Type
USB - on cable: Micro-USB
2600 mAh
Cables
Micro-USB cable
Power bank
2.56 cm
2.56 cm
9.35 cm
68 g
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.4 A
LED indicator
Voltage Provided
5 V
2600 mAh
Overcharge protection, overheat protection, short circuit protection, overdischarge protection, overcurrent protection, overvoltage protection
Micro-USB cable
BRPY C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
BRPY C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
BRPY C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
BRPY C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
BRPY C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
BRPY C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
BRPY C2G USB 2.0 To Fast Ethernet Adapter In Stock £19.05
