Powerful Capacity
Powerful capacity of 10400mAh lets you charge a smartphone 3~5 times, keeping your devices running all the time.
* Actual number of charge times depends on your device's battery size.
Simultaneously Super-fast Charging
Dual USB ports (5V/2A and 5V/1A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones.
Reliable Power
TL-PB10400's multiple protections of short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating ensure safe and reliable charging to avoid any potential harm to your devices.
High Energy Efficiency Rate
Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3~5 times, ideal for extended use of mobile devices.
Practical Functions for Convenience
Smart LED Indicator: Four LED lights work as charge indicators to show battery level or charging status
Practical Flashlight: Built-in flashlight comes in handy for in-house and off-road activities
Universal Compatibility
Compatible with almost any smart devices like iPhones, iPads, Android smartphones and other 5V input USB-charged devices.
Simultaneously super-fast charging
Dual USB ports (5 V/2 A and 5 V/1 A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones. -
Reliable power
TL-PB10400's multiple protections of short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating ensure safe and reliable charging to avoid any potential harm to your devices. -
High energy efficiency rate
Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3-5 times, ideal for extended use of mobile devices. -
Practical functions for convenience
Smart LED indicator: four LED lights work as charge indicators to show battery level or charging status. Practical flashlight: built-in flashlight comes in handy for in-house and off-road activities.
- TP-Link TL-PB10400 power bank - USB
- Product Type
- Power bank
- 4.43 cm x 4.43 cm x 8.88 cm
- 241 g
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 2 A
- Battery
- 10400 mAh
- Cables
- Micro-USB cable
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 4.43 cm
- 4.43 cm
- 8.88 cm
- 241 g
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 V
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2 A
- LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, built-in flashlight, overdischarging protection
- Capacity
- 10400 mAh
- Max Recharge Cycles
- 500
- Included Accessories
- Carrying pouch
- Cables Included
- Micro-USB cable
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
