The TL-ANT5823B 5 GHz 23 dBi outdoor panel antenna is ideal for outdoor use by attaching to your wireless access points/routers which operate on less crowded 5 GHz band, It could be used for long distance point-to-point connection, providing your stable wireless links. It is very easy to use, no configuration or software installation required.
- TP-Link TL-ANT5823B - antenna
- Product Type
- Antenna
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Outdoor, wall-mountable, pole mount
- Compatibility
- 802.11 a/b/g/n
- Frequency Range
- 5.15 - 5.85 GHz
- Gain
- 23 dBi
- Directivity
- Directional
- RoHS, WEEE
- Product Type
- Antenna
Aerial
- Intended For
- Wi-Fi
- Compatibility
- 802.11 a/b/g/n
- Frequency Range
- 5.15 - 5.85 GHz
- Gain
- 23 dBi
- Directivity
- Directional
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x N connector female
- Mounting Kit
- Included
- RoHS, WEEE
