TP LINK TD-W9980 N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Router
Quicklinx: 9L15WS00 Mfr#: TD-W9980
  • IEEE 802.11n
TP-LINK's TD-W9980 N600 Dual Band Gigabit VDSL2/ADSL2+ Modem Router comes with the latest ITU-T G.993.2 VDSL2 standard, providing up to 100Mbps speed downstream and upstream, and backward compatibility with ADSL. With 300Mbps wireless speed over the crystal clear 5GHz band and 300Mbps over the 2.4GHz band, the TD-W9980 is the superior choice for users in search of seamless HD video streaming, online gaming and other bandwidth-intensive tasks. Its all gigabit ports allow users to access high-speed internet connections and share them wirelessly at blazing 300Mbps wireless speeds or by using one of its 4 gigabit LAN ports. With 2 multifunctional USB ports, users can share printers, files and media across the local network or the internet. What's more, this device allows for two different connection types: VDSL/ADSL, or Ethernet WAN, giving users the flexibility to access the Internet whichever method is most convenient. Up to 100Mbps broadband speed
The TD-W9980 supports VDSL2 and backward compatibility with ADSL2+/ADSL2/ADSL, featuring high broadband speeds of up to 100Mbps. It is designed to support the wide deployment of triple play services such as voice, video, data, high-definition television (HDTV) and interactive gaming.
Simultaneous Dual Band
Two separate wireless networks that will run on either the 2.4GHz or 5GHz band, simultaneously. The traditional 2.4GHz band can provides more range and is great for everyday web surfing use but it is more susceptible to interference from wireless devices running on the same frequency. While the 5GHz band can provide faster wireless speeds and avoid much interference .This way, the 5GHz band is just right for bandwidth heavy tasks like on-line gaming and HD streaming. Now you can enjoy both advantages of the two bands by just having one device.
Full Gigabit Ports - More Power to You
With 300Mbps 802.11n wireless and 4 gigabit LAN ports, the TD-W9980 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
2 USB Sharing Ports - Easy Sharing
Using the TD-W9980's two multi-functional USB 2.0 ports, users can share printers, files and media either throughout the network at home with several different computers or even away, using the device's FTP server functions so that you never have to part with your files.
Interchangeable LAN/WAN Port - Versatile Connectivity
The TD-W9980 supports VDSL/ADSL or Ethernet WAN connections (EWAN) that allow users to have the flexibility of different Internet connections among VDSL/ADSL, cable or fiber modem using its interchangeable LAN/WAN port. This unique feature makes it easier when users need to change to fiber or cable services when necessary.
IPv6 Ready
This device supports IPv6, which is foundational to the next generation Internet and enables a range of new services and improved user experiences.
Virtually Impregnable-10 VPN IPsec tunnels
The ability to support up to 10 IPsec VPN tunnels simultaneously gives TD-W9980 users the flexibility to setup a virtual private network, to guarantee network security and take advantage of network access whether at home or away, for work or simply to access files from their local networks.
  • Up to 100 Mbps broadband speed
    The TD-W9980 supports VDSL2 and backward compatibility with ADSL2+/ADSL2/ADSL, featuring high broadband speeds of up to 100 Mbps. It is designed to support the wide deployment of triple play services such as voice, video, data, high-definition television (HDTV) and interactive gaming.
  • Simultaneous dual band
    Two separate wireless networks that will run on either the 2.4 GHz or 5 GHz band, simultaneously. The traditional 2.4 GHz band can provides more range and is great for everyday web surfing use but it is more susceptible to interference from wireless devices running on the same frequency. While the 5 GHz band can provide faster wireless speeds and avoid much interference. This way, the 5 GHz band is just right for bandwidth heavy tasks like on-line gaming and HD streaming. Now you can enjoy both advantages of the two bands by just having one device.
  • Full gigabit ports - more power to you
    With 300 Mbps 802.11n wireless and 4 gigabit LAN ports, the TD-W9980 is the ideal choice for bandwidth heavy users that rely on speedy, reliable connections for bandwidth intensive work or entertainment such as lag-free conference calls, HD video streaming or online gaming.
  • 2 USB sharing ports - easy sharing
  • Interchangeable LAN/WAN port - versatile connectivity
  • IPv6 ready
    This device supports IPv6, which is foundational to the Internet and enables a range of services and improved user experiences.
  • Virtually impregnable-10 VPN IPsec tunnels
TP-Link TD-W9980 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP
Firewall protection, DHCP support, NAT support, NAPT support, IGMP snooping, Stateful Packet Inspection (SPI), print server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, Quality of Service (QoS), Dead Peer Detection (DPD), FTP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
24.3 cm x 16.06 cm x 3.25 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
600 Mbps
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, 128-bit WEP, 64-bit WEP, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
Status Indicators
Port status, power, link/activity
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2, ITU G.995.1
Max Transfer Rate
100 Mbps
WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
External power adapter
ADSL splitter
1 x network cable , 1 x modem cable
24.3 cm
16.06 cm
3.25 cm
10 - 90% (non-condensing)
9L15 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.07
