TP LINK Tapo Smart Wi-Fi Light Bulb Multicolor
Quicklinx: HLWSWS00 Mfr#: Tapo L535E
Type: Light bulb
Compatible With: Alexa, Google Assistant
Hurry, only 1 left in stock!
£9.99 ex VAT
£11.98 inc VAT
Extra Bright Smart Light Bulb - With 1055 lumens (75W Equivalent) of crisp, high-quality lighting, Tapo L535E is ideal for any home space requiring brighter lighting Millions of Colours - Easily design scenarios for your daily routine or activities by customizing the light brightness, light temperature, and colours–with millions of hues to choose from via the Tapo app Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Matter-Certified - With support for the Matter protocol, Tapo L535E can seamlessly interoperate with other certified products across platforms Schedule and Timer - Create a regular schedule to turn on/off with your chosen light effects Voice Control - Manage your smart lights with voice commands via Alexa, Siri, or Google Assistant Remote Control and Away Mode - Instantly turn connected devices on/off wherever you are via the Tapo app. Turn on away mode to simulate someone being at home Energy Monitoring - Monitor your connected devices' real-time power consumption and costs via the Tapo app No Hub Required - Connect directly to your home's secure Wi-Fi network—no need for a hub or extra equipment
  • Effortless control
    With the integration of Smart Wi-Fi technology and compatibility with the Tapo app, controlling your home lighting has never been easier. Adjust brightness, change colors, and set schedules, all from the convenience of your smartphone.
  • Voice activation
    Enhance your smart home experience with voice-controlled convenience. Compatible with Alexa and Google Assistant, this light bulb allows for easy voice commands, making it simple to adjust settings without lifting a finger.
  • Vibrant illumination
    Experience lighting like never before with 16 million colors and a wide color temperature range of 2500-6500 K. Whether you're setting the mood or need optimal light for tasks, this bulb adapts to your needs.
  • Energy efficient
    Designed with an energy efficiency class of E and consuming only 9 kWh per 1000h, this LED light bulb is an eco-friendly choice that doesn't compromise on performance. Enjoy a luminous power of 1100 lumens with just 8.6 W of energy use.
  • Long-lasting durability
    With a lifetime of 25,000 hours and 15,000 switch cycles, this bulb is built to last. Its quick warm-up time of 1 sec ensures immediate brightness, providing convenience and reliability in your home lighting.
Tapo Smart L535E - LED light bulb - shape: A60 / A19 - E27 - 8.6 W - 16 million colours - 2500-6500 K
Recommended For
Home
Light Source Type
LED light bulb
Usage Modes
Away
Shape
A60 / A19
Socket Type
E27
Wattage
8.6 W
Wattage Equivalent
75 W
Energy Efficiency Class
E
Colour of Illumination
16 million colours
Colour Temperature
2500-6500 K
Luminous Power
1100 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Tapo, Matter
Communications Technology
Wi-Fi
220 - 240 V
Frequency Required
50/60 Hz
Recommended For
Home
Usage Modes
Away
Light Source
LED light bulb
Shape
A60 / A19
Socket Type
E27
Wattage
8.6 W
Wattage Equivalent
75 W
E
Energy Consumption per 1000h
9 kWh
16 million colours
Colour Temperature
2500-6500 K
Colour Rendering Index
90
Luminous Power
1100 lumens
Beam Angle
220 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
25000 hours
Switch Cycles
15000
Voice control, light scheduling, app-controlled, remote controlled, Smart Wi-Fi technology, multicolour
Power Requirements
220 - 240 V
Frequency Required
50/60 Hz
9.5 Watt
Power Consumption Stand by
0.2 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo, Matter
Compatible Application
Tapo app
Wi-Fi
Voice Controlled
Indirect
Package
Box
FCC, ETL, DOE, CEC, RCM, SAA, ERP, UKCA
Diameter
60 mm
Length
115 mm
65 g
-15 °C
Type: Light bulb
Brand: TP LINK
