Remote Control – Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule – Preset a schedule to automatically manage devices
Timer - Create countdown timer lists for connected electronics
Voice Control – Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design - Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use - No hub required, set up quickly and manage easily through the free app
                Smart control from your mobile deviceManage your connected devices from anywhere with the Tapo app. It's designed to support your lifestyle and keep your family safe.
                No internet, no problemsControl your connected devices through your Tapo app, even when the Internet is down. Your schedules will continue, regardless of connections.
                Save money and energyMonitor real-time power consumption and energy spend via the Tapo app. Save smarter by managing your appliances for when electricity is cheaper.
                Group devices for one-tap controlCombine several devices under one group, so your smart plug works with other Tapo smart devices. Turn them all on or off with one action - no need for repeated actions anymore.
                Mighty features and compact sizeTapo P110 is built small to leave adjacent sockets open, making it convenient for daily use.
                Share to familiesNot limited to single control, family members can directly share management permissions with each other, saving time and enhancing user-friendliness.
                Safety at home, while awayAway Mode simulates someone being at home. Deter thieves and those of ill intent with plugged-in devices turning on and off at scheduled times.
                Enjoy easy, friendly setup and useUnique onboarding technology makes setup steps simpler for faster connection (within 20 seconds).
- Tapo P110 V1 - smart plug - mini - 802.11b/g/n (pack of 4)
- Product Type
- Smart plug
- Packaged Quantity
- 4 (specifications are for single item)
- Functions
- Energy use monitor, turn electronics on/off
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- Supported Host Device OS
- iOS, Android
- 2-year warranty
- 5.15 cm x 3.06 cm x 7.25 cm
- Packaged Quantity
- Product Type
- Smart plug
- Functions
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- Android 4.4 (KitKat) or later, iOS 9 or later
- On / off button, Away Mode, remote access, voice control, LED indicator, timer, flame-retardant, up to 2990 Watt, schedule function, 13 A max load current
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Type
- Cloud
- Communications Technology
- Wi-Fi
- Voice Controlled
- Indirect
- Product Material
- Polycarbonate
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP, WPA3
- Voltage Required
- AC 100-240 V
- Warranty
- 2-year warranty
- RoHS, PC UL94 V0
- 5.15 cm
- 3.06 cm
- 7.25 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
