TP LINK Tapo L930-10 - Light strip - LED - 24 W - RGBW light - 2500
Quicklinx: HLWWWS00 Mfr#: Tapo L930-10
Type: Light strip
Compatible With: Alexa, Google Assistant
£58.33 ex VAT
£69.99 inc VAT
Zonal Color Control - make the most of 50-section addressable color zones, to suit every mood or scenario setting Extra White LEDs - act as general lights, strengthening the practicability of the colourful Wi-Fi light strip Fancy Lighting Effects - amuse yourself with well-designed animated lighting effects, available on Tapo App Music Sync - adds more vibe by emitting dynamic lights, parallel with the surrounding music beat Apple HomeKit Supported - control your light strip with Siri using Apple HomeKit Surface Coating-stays durable, tidy, and complete, thanks to the high-quality PU coating on its surface. Compatible with your smart voice assistants, including Alexa and Google Assistant Easy Setup - attach the Light Strip with 3M Adhesive on desired spots, connect it to Wi-Fi and configure it via App
  • Flexible design
    The Tapo L930-10 light strip features a flexible design with 3M adhesive tape mounting, making it easy to install in any corner of your home for that perfect ambient lighting.
  • Smart control
    With Wi-Fi connectivity and compatibility with the Tapo app, Alexa, and Google Assistant, this light strip offers app-controlled and voice-controlled lighting adjustments, including dimming, color changes, and power on/off schedules.
  • Vibrant lighting options
    Boasting 16 million changeable colors and 50 color zones, the Tapo L930-10 allows for personalized lighting setups that can sync with your music, enhancing any entertainment experience.
  • Energy-efficient illumination
    Equipped with a built-in LED lamp that has a lifetime of 25,000 hours and a luminous power of 2000 lumens, this light strip provides bright, energy-efficient lighting with a quick warm-up time of 1 sec.
  • Customizable settings
    From lighting schedules to away modes, the Tapo L930-10 offers a range of customizable features, including cuttable sections for a tailored fit and a dimmable range from 1 to 100%, ensuring the right light for every moment.
Tapo L930-10 - light strip - LED - 24 W - RGBW light - 2500-6500 K (pack of 2)
Light strip
Light Source Type
LED
Packaged Quantity
2 (specifications are for single item)
Usage Modes
Music sync, away
Wattage
24 W
Colour of Illumination
RGBW light
Colour Temperature
2500-6500 K
Luminous Power
2000 lumens
Luminous Power per Length
200 lumens/m
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Apple HomeKit
Communications Technology
Wi-Fi
AC 100 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Light strip
Usage Modes
Music sync, away
Flexible, 3M adhesive tape mounting, cuttable, app-controlled, lighting schedules, Wi-Fi (2.4 GHz) controlled, power on/off timer, voice control, 1 - 100% dimmable, 50 colour zones, 2 strips from 1 controller
Light Source
LED
Built-in LED Lamp
Wattage
24 W
RGBW light
Colour Temperature
2500-6500 K
Colour Rendering Index
80
Luminous Power
2000 lumens
200 lumens/m
Warm-Up Time
1 sec
Dimmable
Lifetime
25000 hours
Colour changing LED, 16 million changeable colours, RGB colour changing control, white LED
Power Requirements
AC 100 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.4 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Apple HomeKit
Compatible Application
Tapo app
Supported Host Device Platform
iOS, Android
Wi-Fi
Voice Controlled
Indirect
Product Material
Polyurethane (PU)
Power adapter, controller, mounting adhesive
Package
Box
VCCI, BSMI, IC, FCC, RoHS, NCC, RCM, JRF, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 cm
0.3 cm
Length
5 m
-15 °C
Type: Light strip
Brand: TP LINK
