TP LINK Tapo L530B - LED light bulb - B22 - 8.7 W (equivalent 60 W)
Quicklinx: GLM5WS00 Mfr#: TAPO L530B(2-PACK)
Type: Light bulb
Compatible With: Alexa, Google Assistant
£12.49 ex VAT
£14.98 inc VAT
With L5350E and the Tapo app, you just need one tap on your smart phone, then everything is on. No matter how late you arrive home ,Tapo is always there. Welcome home!
Connect the L530E Light to your home Wi-Fi network, then you are all set. No need for extra hubs or other devices. Advanced technology allows Tapo L530 to use less energy than normal LED lights - only 8.7 W for 806 lm (60 W equivalent).
  • Multicolor
    Easily design scenarios for your daily routine or activities by customizing brightness, light temperature, and colors - with 16,000,000 hues to choose from.
  • 60-watt equivalent
    LED bulb produces up to 806 lumens white brightness and has a dimming range from 1% to 100%.
  • Preset for convenience
    Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
  • Schedule & timer
    Create schedules and count plans to turn on/off with the brightness/color you set.
  • Sunrise and sunset modes
    Automatically activate your light according to your time zone.
  • No hub required
    Connect the L530B light to your home Wi-Fi, then you are all set.
  • Voice control
    Manage the lights with your voice commands as Tapo works with Amazon Alexa and Google Assistant.
  • Remote control
    Take your phone out for the pocket and open the Tapo app to control your light remotely.
  • Away mode
    Automatically simulate someone being at home to frighten away, unwanted visitors.
Tapo L530B - LED light bulb - B22 - 8.7 W - 16 million colours - 2500-6500 K (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Socket Type
B22
Wattage
8.7 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
16 million colours
Colour Temperature
2500-6500 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Tapo
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Light Source
LED light bulb
Socket Type
B22
Wattage
8.7 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
9 kWh
16 million colours
Colour Temperature
2500-6500 K
Luminous Power
806 lumens
Beam Angle
220 degree(s)
Warm-Up Time
1 sec
Dimmable
Lifetime
15000 hours
Switch Cycles
15000
Automatic colour changing mode, 1%-100% dimmable, Android compatible, iOS compatible, remote controlled, app-controlled, programmable usage modes, adjustable colour temperature, power on/off timer, Wi-Fi (2.4 GHz) controlled, away mode
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
0.14 Watt
Internet of Things (IoT)
Hub
Not needed
Platform
Tapo
Compatible Application
Tapo app
Wi-Fi
Voice Controlled
Indirect
RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Diameter
60 mm
Length
115 mm
74 g
Type: Light bulb
Brand: TP LINK
