Tapo Smart Battery Video Doorbell
2K 5MP Live View
Always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 5MP resolution, check all the fine details captured even in low-light environments.
Color Night Vision
With the embedded spotlight and starlight sensor, Tapo D230S1 reveals high-fidelity details and color at night.
Head-to-Toe View
With the camera’s ultra-wide FOV(160° Diagonal), Tapo 4:3 live view ensures users can check visitors from head-to-toe as close as 1m†, which shows more vertical details than other 16:9 doorbells'.
Flexible Placement, Flexible Views
Different wedge choices allow users to make the doorbell suits more placement scenarios. Users can also use wedges to adjust the views.
Longer Battery Life
The rechargeable and removable battery with a low-power protocol extends your usage.
Smart AI Detection and Notification
Smart AI algorithms identify people and cars, and notify users as needed.
Multiple Ways to Answer
With two-way audio or a recorded quick response, communicate directly with your deliveries through the Tapo app.
Flexible Storage Choice
Save recorded videos on the hub-installed microSD card§ (up to 512 GB) or by using Tapo Care cloud storage services (subscription required).
Anti-theft Alarm
Be alerted when someone trying to take the doorbell off with the anti-theft alarm function.
Water & Dust Resistant IP64
Operates well on rainy days and in damp environments.
2K 5MP live view
Always know what happens in front of your door through the Tapo app. With the starlight sensor and 2K 5MP resolution, check all the fine-details captured even in low-light environments. -
Color night vision
With the embedded spotlight and starlight sensor, Tapo D230S1 reveals high-fidelity details and color at night. -
Head-to-toe view
With the camera's ultra-wide FOV (160° Diagonal), Tapo 4:3 live view ensures users can check visitors from head-to-toe as close as 1 m, which shows more vertical details than other 16:9 doorbells' -
Flexible placement, flexible views
Different wedge choices give users possibilities to make the doorbell suits more placement scenarios. Users can also use these wedges to adjust the views. -
Longer battery life
The rechargeable and removable battery with a low-power protocol extends your usage. -
Person and vehicles detection
Powerful Al identifies people or vehicles, notifying users with filtered notifications. -
Multiple ways to answer
- Tapo D230S1 V1 - Video Doorbell Camera Kit - smart doorbell - 802.11b, 802.11g, 802.11n
- Product Type
- Smart doorbell - with camera
- Placing / Mounting
- Wall-mounting
- Functions
- Camera, entry chime
- Integrated Sensors
- Motion sensor, light sensor, alarm
- Integrated Components
- Microphone, speaker
- Power Source
- Battery
- Intelligent Assistant
- Alexa, Google Assistant
- Connectivity
- Wireless - 802.11b, 802.11g, 802.11n
- Frequency Band
- 2.4 Ghz
- Camera
- Max Resolution 2560 x 1920 - audio - Day&Night
- 2-year warranty
- Product Type
- Functions
- Power Source
- Battery
- Wall-mounting
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 Ghz
- Smart notification, 2-way audio, selectable ringtones, LED indicator AES encryption, Internet Control Message Protocol (ICMP), DNS support, HTTPS support, TCP support, UDP support, TCP/IP support
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Tapo H200
- Compatible Application
- Tapo app
Camera
- Day & Night Functionality
- Audio Support
- Max Digital Video Resolution
- 2560 x 1920
- 5 megapixels resolution, 4:3 aspect ratio, Smart AI Detection, Colour Night Vision, 160° field of view (diagonal), AI Person Detection, AI vehicle detection, 1/2.7 CMOS image sensor type, F 2.1 lens aperture, 15 fps
- Rechargeable Battery
- Rechargeable
- Capacity (Ah)
- 6700 mAh
- Battery Lifetime
- 180 days
- Encryption Algorithm
- 128-bit AES, SSL, TLS, WPA, WPA2-PSK
- Warranty
- 2-year warranty
- IP64, EAC, UKCA
- Dimensions & Weight Details
- Camera: 5.45 cm x 14.6 cm x 3.55 cm , Hub: 7.145 cm x 7.145 cm x 3.125 cm
- -20 °C
- 45 °C
- 10 - 90% RH (non-condensing)
