TP LINK Tapo C320WS Outdoor Security Wi-Fi Camera
Quicklinx: GLJYWS00 Mfr#: Tapo C320WS
Type: Outdoor Camera
Compatible With: Alexa, Google Assistant
  • microSD Card
27 In Stock
£34.99 ex VAT
£41.98 inc VAT
2K QHD-Records every image in crystal-clear 2560x1440 definition.
Wired or Wireless Networking-Connect your camera to the network through Ethernet or WiFi for more flexible installation.
Full-Color Night Vision-Bring you a colorful video even at night.
Starlight Night Vision-Provide a stable view with more details even in the starlight.
Motion Detection and Notifications-Notifies you when the camera detects movement.
Sound and Light Alarm-Trigger light and sound effects to frighten away unwanted visitors.
Two-Way Audio-Enables communication through a built-in microphone and speaker.
Safe Storage-Locally stores up to 512 GB 2K QHD video on a microSD card, offering convenient access to your video footage.
Voice Control-Free Up Your Hands with Voice Control: Works with the Google Assistant and Amazon Alexa. (Google Assistant and Amazon Alexa are not available in all languages and countries).
  • 2K QHD, clear and bright every second
    With a resolution of 2560x1440, QHD delivers more delicate detail. The feature of 8x magnification can also help you see further.
  • Vivid full-color sight at dark night
    Different from the black and white view of normal cameras, Tapo C320WS is equipped with the high resolution sensor and the fill light, catching more colors.
  • Brighter, even for starlight
    The high-sensitive starlight sensor captures higher-quality images even in low-light conditions so details won't get lost in the shadows.
  • High-decibel siren alarm
    You can start the build-in siren for deterrent. And the siren alarm can also co-work with the different motion detections automatically.
  • Two-way audio
    Always be on site with two-way audio. Communicate with a delivery person for your convenience.
Tapo C320WS V1 - network surveillance camera
Network surveillance camera - fixed - outdoor - dustproof / weatherproof
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
14.23 cm x 10.34 cm x 6.43 cm
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
2560 x 1440
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1440p
Optical Sensor Type
1/2.7" - 4 MP
Focal Length Control
Fixed focal
Focal Length
3.89 mm
Lens Iris
F/2.2
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX/1000Base-T
Voltage
AC 100-240 V, DC 9 V
Voice control, Push Notification, reset button, LED indicator, night vision, alarm function, built-in siren
Environmental Parameters (operating)
-20 °C - 45 °C; 10 - 90% (non-condensing) relative humidity
Audio Support
Wired, wireless
14.23 cm
10.34 cm
6.43 cm
Camera
Colour - Day&Night - fixed - outdoor - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
2560 x 1440
Motion Detection
Video Modes
1440p
Infrared LEDs
Infrared Distance
30 m
Video Capture
2560 x 1440 @ 15 fps
Image Sensor
4 MP 1/2.7"
Lens Construction
Fixed focal
Focal Length
3.89 mm
Lens Iris
F/2.2
Network Interface
Network Protocols
SSL, TLS
Ports
LAN - RJ-45
Supported Memory Cards
microSD Card
Mounting template, anchors, screws, waterproof seal, cable waterproof connectors
NCC, AES-128, WPA2-PSK, WPA-PSK, SSL, TLS, IP66
Power Requirements
DC 9 V - 0.6 A
Power adapter - external AC 100-240 V (50/60 Hz)
Android 4.4 or higher, Apple iOS 9 or later
-20 °C
45 °C
Relative Humidity (operating)
Brand: TP LINK
