TP-LINK's T3700G-28TQ is an L3 managed switch designed to build a highly accessible, scalable, and robust network. The switch is equipped with 24 Gigabit RJ-45 ports, 4 Combo Gigabit SFP and up to 4 10Gbps SFP slots, giving network administrator great network flexibility.
It supports abundant Layer 3 routing protocols such as RIP and OSPF which are a critical part in the creation of fully resilient scalable networks. What's more, with physical stacking feature and optional redundant external power unit, T3700G-28TQ provides a robust network with efficient redundancy.
T3700G-28TQ provides robust security to help secure your enterprise network.
TP-LINK's T3700G-28TQ L3 managed switch provides a reliable and cost-effective solution for enterprise, campus and ISP networks.
- TP-Link JetStream T3700G-28TQ - switch - 28 ports - Managed - rack-mountable
- Switch - 28 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
- Performance
- Switching capacity: 128 Gbps , Forwarding performance: up to 95.2 Mpps
- Capacity
- IP router interfaces: 128 , Static routes: 256 , Virtual interfaces (VLANs): 4000
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 10240 bytes
- Routing Protocol
- RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, ECMP
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
- Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, PIM-SM snooping, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, LACP support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Dynamic VLAN Support (GVRP), dual firmware images, Neighbor Discovery Protocol (NDP), PIM-DM snooping
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 33 cm x 4.4 cm
- System Requirements
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7, Windows 8
- Enclosure Type
- Desktop, rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 32K entries
- 10240 bytes
- Max Units In A Stack
- 8
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, SSL 3.0, SSL 2.0
- Authentication Method
- Secure Shell (SSH), RADIUS
- Built-in Devices
- Led panel
- Status Indicators
- Power, system, RPS (Redundant Power Supply), link/activity
- 24 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45 management
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Power Provided
- 150 Watt
- Voltage Required
- 63 Watt
- Redundant Power System (RPS) connector
- Included Accessories
- 4 rubber feet
- Rack Mounting Kit
- Included
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 44 cm
- 33 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.20 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.76 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.24 |
