Product
TP LINK T3700G-28TQ  JetStream 28-Port Gigabit Stackable L3 Managed
Quicklinx: B0QJWS00 Mfr#: T3700G-28TQ
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£1,168.08 ex VAT
£1,401.69 inc VAT
TP-LINK's T3700G-28TQ is an L3 managed switch designed to build a highly accessible, scalable, and robust network. The switch is equipped with 24 Gigabit RJ-45 ports, 4 Combo Gigabit SFP and up to 4 10Gbps SFP slots, giving network administrator great network flexibility.
It supports abundant Layer 3 routing protocols such as RIP and OSPF which are a critical part in the creation of fully resilient scalable networks. What's more, with physical stacking feature and optional redundant external power unit, T3700G-28TQ provides a robust network with efficient redundancy.
T3700G-28TQ provides robust security to help secure your enterprise network.
TP-LINK's T3700G-28TQ L3 managed switch provides a reliable and cost-effective solution for enterprise, campus and ISP networks.
TP-Link JetStream T3700G-28TQ - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP + 2 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: up to 95.2 Mpps
IP router interfaces: 128 , Static routes: 256 , Virtual interfaces (VLANs): 4000
MAC Address Table Size
32K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, ECMP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, SSH-2, CLI
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, PIM-SM snooping, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, LACP support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), Dynamic VLAN Support (GVRP), dual firmware images, Neighbor Discovery Protocol (NDP), PIM-DM snooping
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s
44 cm x 33 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 98SE/2000/NT/ME/XP/Vista/7, Windows 8
Enclosure Type
Desktop, rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
10240 bytes
Max Units In A Stack
8
Routing Protocol
Encryption Algorithm
TLS 1.0, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS
Built-in Devices
Led panel
Status Indicators
Power, system, RPS (Redundant Power Supply), link/activity
24 x 1000Base-T RJ-45 , 4 x Gigabit LAN SFP , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45 management
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Power Provided
150 Watt
63 Watt
Redundant Power System (RPS) connector
4 rubber feet
Rack Mounting Kit
Included
FCC, RoHS
Software Included
Drivers & Utilities
44 cm
33 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
B0QJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
B0QJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
B0QJ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.24
Ports: 28
Managed: Yes
POE: No
Brand: TP LINK
Price Range Ex VAT: 1000 - 1500
