TP LINK Starter Pack - x3 Smart Bulbs, x2 Smart Plugs
Quicklinx: FSCHWS00 Mfr#: 400015414
Compatible With: Alexa, Google Assistant
Stock Status: Clearance
49 left in stock
£66.66 ex VAT
£79.99 inc VAT
Express delivery Order within the next 8 hours for delivery tomorrow
Starter Pack Contains:
TP Link Kasa Smart Wi-Fi LED Bulb with Dimmable Light x 2
TP Link Kasa Smart Wi-Fi LED Bulb with Multicolour x 1
TP Link Kasa Smart Wi-Fi Plug with Energy Monitoring x 2
LB110 - Kasa Smart Wi-Fi LED Bulb with Dimmable Light:
No Hub Required – Connect the bulb to your Wi-Fi at home
Manage Remotely – Easy setup and control from anywhere with the free Kasa app (iOS, Android)
Dimmable Light – Adjust brightness to suit your mood
Voice Control – Pair to Amazon Alexa and the Google Assistant to enable voice control
Monitor Power – Track real-time energy used to stay informed
Save Energy – Reduce energy use up to 80% without brightness or quality loss compared to a 60W incandescent bulb
Compatibility – Compatible with Android, iOS and Amazon Alexa and the Google Assistant
LB130 - Kasa Smart Wi-Fi LED Bulb with Multicolour:
No Hub Required – Connect the bulb directly to your Wi-Fi at home
Colour Changing – Fine-tune colours for every occasion and adjust brightness as well as light appearance from soft white (2500k) to daylight (9000k)
Circadian Mode – Dynamically adjust light intensity and temperature to mimic natural light patterns
HS110 - Kasa Smart Wi-Fi Plug with Energy Monitoring:
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Energy Monitoring – Analyze a device’s real-time and historical power consumption.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control
Brand: TP LINK
Price Range Ex VAT: 50 - 100
