TP LINK LB110 Smart Wi-Fi E27 LED Bulb with Dimmable Light
Quicklinx: CNZKWS00 Mfr#: LB110
Control your lighting from anywhere with the LB110. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa also lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. For added convenience, you can use your voice to control the LB110 when paired with Amazon Alexa.
Highlights:
* Works with Amazon Alexa for voice control (Alexa device sold separately)
* 60 Watt Equivalent, 2700K Soft White
* Control your lights from anywhere with your tablet or smartphone using the free kasa app (Android 4.1 or higher / iOS 8 or higher)
* Dim brightness to customize Lighting and suit your mood
* Set schedules, timers, and countdowns and have your lights work around your life
* No hub required; works with your Wi-Fi router
Package Contents:
* Smart Wi-Fi LED Bulb LB110
* Quick Installation Guide
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
  • Manage remotely
    Connect the LB110 to your home Wi-Fi network and control it from anywhere.
  • Fine-tune your lighting
    With adjustable brightness, the LB110 lets you customize your lighting to suit your mood at any time.
  • Enjoy peace of mind
    Schedule the LB110 smart bulbs around your life and have them to turn on and off at different times. They can even adjust automatically to changing sunset and sunrise times so it comes on when it gets dark and turns off as the sun comes up.
  • Away mode
    Improve your home security when you're not there by turning your lights on and off at different times, giving the appearance that you're home.
TP-Link LB110 - LED light bulb - shape: A19 - E27 - 10 W - warm white light - 2700 K
Light Source Type
LED light bulb
Shape
A19
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
180 degree(s)
Dimmable
Intelligent Assistant
Alexa
Communications Technology
Wi-Fi
AC 220 - 240 V
Frequency Required
50 Hz
Light Source
LED light bulb
Shape
A19
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
A+
Warm white light
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
180 degree(s)
Dimmable
Lifetime
25000 hours
Android compatible, iOS compatible, voice control
Power Requirements
AC 220 - 240 V
Frequency Required
50 Hz
Internet of Things (IoT)
Wi-Fi
Alexa
EMC, RoHS
170 g
-15 °C
Resources
The following resources are available for the TP LINK LB110 Smart Wi-Fi E27 LED Bulb with Dimmable Light
