TP LINK RPS150 150W Redundant Power Supply
Quicklinx: B1D8WS00 Mfr#: RPS150
The TP-LINK Redundant Power Supply (RPS) RPS150 is designed to maximize availability for business networks.
RPS150 is used as a redundant power supply for TP-LINK RPS capable L2 and L3 Managed switches. When working with these switches, RPS150 provides a quick failover feature to ensure that the connected switches can work uninterrupted in the event of an internal power supply failure.
Without any necessary configuration, RPS150 can be easily installed as an independent power supply unit, or placed inside RPS2 chassis which is designed to accommodate two RPS150s for rack-mounted installation. Overall, the system integration between TP-LINK's managed switches and RPS devices provides a resilient and highly accessible converged network at an affordable price.
TP-Link RPS150 - power supply - redundant - 150 Watt
Power supply - redundant - external
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
150 Watt
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
12 V
Power Capacity
150 Watt
2 x power cable - external
LED indicators, over current protection, over voltage protection, undervoltage protection, short-circuit protection
20 - 90% (non-condensing)
