Powerful quad-antenna design with Beamforming delivers highly targeted Wi-Fi connections to improve throughput and signal quality for stronger Wi-Fi across your home, while extending your routers coverage. The Intelligent Processing Engine balances the demands of your devices to keep their connections fast and uninterrupted, sending Wi-Fi traffic to dedicated processors while the powerful CPU handles the rest. Using 4-Stream and TurboQAM technology to boost its Wi-Fi bandwidth, the RE650 reaches industry leading maximum speeds. This provides the performance necessary to support your demanding online applications. MU-MIMO technology allows the RE650 to serve up several devices at once, reducing wait time and greatly increasing Wi-Fi throughput for every device. With MU-MIMO, the RE650 runs faster than traditional AC range extender. The RE650's Gigabit Ethernet port lets you connect a wired device such as a game console or smart TV to create a fast, reliable wired connection. If one of the main router's dual bands drops suddenly, or in case the main router can only deliver single band, the RE650 still provides stable dual-band connections for clients, allowing you to enjoy stable and drop-free experience on all your devices.
Far reaching Wi-Fi and powerful performance
Powerful quad-antenna design with Beamforming delivers highly targeted Wi-Fi connections to improve throughput and signal quality for stronger Wi-Fi across your home, while extending your routers coverage. The Intelligent Processing Engine balances the demands of your devices to keep their connections fast and uninterrupted, sending Wi-Fi traffic to dedicated processors while the powerful CPU handles the rest. -
4-Stream dual band Wi-Fi
Using 4-Stream and TurboQAM technology to boost its Wi-Fi bandwidth, the RE650 reaches industry leading maximum speeds. This provides the performance necessary to support your demanding online applications. -
More connections and faster for everyone
MU-MIMO technology allows the RE650 to serve up several devices at once, reducing wait time and greatly increasing Wi-Fi throughput for every device. With MU-MIMO, the RE650 runs faster than traditional AC range extender. -
High-speed Gigabit wired connection
The RE650's Gigabit Ethernet port lets you connect a wired device such as a game console or smart TV to create a fast, reliable wired connection. -
Drop-free and seamless dual band connections
- TP-Link RE650 - Wi-Fi range extender - Wi-Fi 5, Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Processor
- 1 x 880 MHz
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Windows 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
- 8.6 cm x 4 cm x 16.3 cm
- 8.6 cm
- 4 cm
- 16.3 cm
- Localisation
- United Kingdom
Processor / Memory / Storage
- Processors Installed
- 1 x 880 MHz
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 2600 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, beamforming technology, 4x4 MU-MIMO technology, Intelligent Signal Light
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External integrated
- Antenna Qty
- 4
- 1 x 1000Base-T - RJ-45
- FCC, RoHS
- Power Device
- Internal power supply
- 12 Watt
- OS Required
- 10 - 90% (non-condensing)
