TP LINK RE200 AC750 WiFi Range Extender
Quicklinx: 9L13WS00 Mfr#: RE200
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 750Mbps
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: Mac, PC
  • IEEE 802.11n
14 in stock
£25.89 ex VAT
£31.06 inc VAT
Boost Your Router Coverage to Expanded Dual Band WiFi
RE200 expands your existing WiFi coverage with next generation 11AC WiFi technology. It works with any standard WiFi router and creates stronger dual band connections in hard-to-reach areas, allowing you to enjoy seamless wireless coverage throughout your home or office.
Next Generation 11AC WiFi
Create faster access for 802.11 b/g/n and 802.11ac WiFi devices. RE200 delivers fast speeds of dual band WiFi up to 750Mbps and provides reliable connections for laptops, smartphones, tablets and other wireless-enabled devices.
*Actual WiFi speeds may vary due to different user environments.
Enjoy Super Speeds in High Speed Mode
With High-Speed technology, RE200 makes the best use of both WiFi bands to establish super speedy connections -- ideal for HD video streaming, online gaming and other bandwidth-intensive tasks.
*In high speed mode, RE200 offers maximum performance but limits connection to one band (2.4GHz or 5GHz).
Easy Setup and Flexible Placement
Press the WPS button on your router and the Range Extender button on your RE200 within 2 minutes to easily connect to the network. Once connected with an existing router, you can simply unplug and plug the RE200 back in anywhere within the wireless range of the existing router, without needing to configure the extender again.
*The band used when connecting via the WPS buttons is sometimes indefinite and dependant on the settings on your router. If you want to establish a WPS connection in both 2.4GHz and 5GHz bands, please go to the RE200's web configuration page to configure this.
Entertainment Adapter
The RE200's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
  • Boost your router coverage to expanded dual band Wi-Fi
    RE200 expands your existing Wi-Fi coverage. It works with any standard Wi-Fi router and creates stronger dual band connections in hard-to-reach areas, allowing you to enjoy seamless wireless coverage throughout your home or office.
  • Enjoy great speeds in High Speed mode
    With High-Speed technology, RE200 makes the perfect use of both Wi-Fi bands to establish super speedy connections - ideal for HD video streaming, online gaming and other bandwidth-intensive tasks.
  • Easy setup and flexible placement
    Once connected with an existing router, you can simply unplug and plug the RE200 back in a location for the perfect signal quality and coverage in your house, without needing to configure the extender again.
  • Smart signal indicator
    Smart signal lights show the strength of signal that RE200 receives from the existing router, which can help to find the perfect location for optimal Wi-Fi coverage.
  • Entertainment adapter
    The RE200's single Ethernet port allows the extender to function as a wireless adapter to connect wired devices like Blu-ray players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
TP-Link RE200 - Wi-Fi range extender
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
11 cm x 6.58 cm x 7.52 cm
11 cm
6.58 cm
7.52 cm
External
Wireless
Data Transfer Rate
750 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
TCP/IP, DHCP
Frequency Band
2.4 GHz, 5 GHz
DHCP support, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), wireless bridge mode, reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
3
1 x 100Base-TX - RJ-45
1 x network cable
FCC, RoHS
Internal power supply
6.5 Watt
Software Included
Drivers & Utilities
10 - 90% (non-condensing)
9L13 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
9L13 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
9L13 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
9L13 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.24
Speed: 750Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: TP LINK
Price Range Ex VAT: 0 - 50
