TP LINK Powerline AV2000 Gigabit Powerline ac - Wi-Fi Kit
Quicklinx: D0B0WS00 Mfr#: TL-WPA9610KIT
Hurry, only 2 left in stock!
£115.27 ex VAT
£138.32 inc VAT
The AC1200 dual-band Wi-Fi provides very fast speeds, delivering a seamless wireless network to all your smartphones, tablets and computers.
  • Stable connections
    2x2 MIMO is like adding extra lanes to a highway. This increases transfer speeds, and avoids interference from other appliances, providing speed with stability.
  • High-speed Wi-Fi
    Get high-speed Wi-Fi for streaming and lag-free gaming on multiple devices at the same time.
  • Simple, smarter Wi-Fi sync
    Wi-Fi sync combines two technologies for a simple, smart network. Pressing the Wi-Fi clone button instantly copies your network name and password from your router for easy setup. Wi-Fi move automatically applies any settings changes across the network.
TP-Link Powerline AV2000 Gigabit Powerline ac - Wi-Fi Kit - bridge - 802.11a/b/g/n/ac - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2000 Mbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Quality of Service (QoS), 2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV, HomePlug AV 2.0, IEEE 802.11ac
14.05 cm x 7.75 cm x 4.8 cm
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2000 Mbps
Max Range Indoors
300 m
Routing Protocol
Encryption Algorithm
128-bit AES
Status Indicators
Power, WLAN, LAN
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
14 Watt
TP-Link TL-WPA9610, TP-Link TL-PA9020
2 x network cable - 2 m
14.05 cm
7.75 cm
4.8 cm
10 - 90% (non-condensing)
Brand: TP LINK
Price Range Ex VAT: 100 - 150
