The PoE Splitter TL-POE10R fully complies with IEEE 802.3af standard, and can work with all IEEE 802.3af PoE compliant PSE (Power Source Equipment) or PoE supplier adapter or other equivalent product, to deliver 12V or 5V direct current to where there are no power line or outlet, where you wish to fix device such as AP, IP camera or IP phone, and so on.
- TP-Link TL-POE10R - PoE splitter
- PoE splitter - external
- Input Connectors
- RJ-45
- Output connectors
- 1 x power DC jack
- 8.1 cm x 5.2 cm x 2.4 cm
- Input Connectors
- RJ-45
- Power Output Connectors Details
- 1 x power DC jack
- 1 x LAN - RJ-45
- 0 °C
- 40 °C
- 0 - 90%
- 8.1 cm
- 5.2 cm
- 2.4 cm
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
7YT4 043320 Condition: Customer return - item has been opened but is in excellent condition |
£4.77 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
