TP LINK PoE kit PoE Kit 1 Injector + 1 Splitter 12/9/5V
Quicklinx: 896LWS00 Mfr#: TL-PoE200
The TL-POE200 is designed to deliver power and data over a single Ethernet cable to an Ethernet enabled device up to 100m away. The PoE kit uses two devices, one, the 'injector' injects power and data into a single Ethernet cable while the other, the 'splitter' placed at the receiving end splits the power and data back into two cables to be used by the connected Ethernet device. This convenience allows users to place Ethernet enabled devices such as access points, IP cameras, or VoIP phones anywhere that they are best suited, regardless of whether a power socket is available, to achieve the best performance for the connected devices.
TP-Link TL-POE200 - repeater - 10Mb LAN, 100Mb LAN
Repeater
External
10Mb LAN, 100Mb LAN
Max Transfer Distance
100 m
Power Over Ethernet (PoE)
PoE
8.1 cm x 5.2 cm x 2.4 cm
Repeater
External
Wired
10Mb LAN, 100Mb LAN
100 m
IEEE 802.3, IEEE 802.3u
1 x Ethernet 10Base-T/100Base-TX (PoE) - RJ-45
PoE
8.1 cm
5.2 cm
2.4 cm
10 - 90% (non-condensing)
