The TL-ANT24PT3 pigtail cable is ideal for flexible connection between rigid outdoor cable and wireless access points/routers. It is very easy to use, no configuration or installation software required.
- TP-Link TL-ANT24PT3 Pigtail Cable - antenna cable - 3 m
- Antenna cable
- Length
- 3 m
- Connector
- N-Series connector - male
- Connector (Second End)
- RP-SMA - male
- Network Cable Type
- Antenna cable
- Impedance
- 50 Ohm
- Length
- 3 m
- Connector
- RP-SMA - male
- -10 °C
- 60 °C
