Product
TP LINK PB50 10000mAh Power Bank Dual 5V USB Smart Charge
Quicklinx: BRPLWS00 Mfr#: PB50
PB50 comes equipped with a intelligent chip to recognize users device, and delivering the max-imum speed required, whether iOS, Android or other USB-enabled devices. The lithium polymer 10000 mAh battery is designed to provide users with a lighter, more powerful energy source that increases its portability and ensures that it continues working for you long after everyone else has gone home.
  • Intelligent full speed charging
  • Increased portability that powers your devices safely
    The lithium polymer 10000mAh battery is designed to provide users with a lighter, more powerful energy source that increases its portability and ensures that it continues working for you long after everyone else has gone home.
  • Power that goes the distance
    With a recharge life cycle of up to 500 times, the PB50 is a device that stands the test of time. This provides users with a long-lasting platform that continuously powers their lives and businesses when they need it most.
  • Stay on top of your power usage
    The PB50 comes standard with an accurate 4 stage smart LED indicator that helps to show how much battery is left so users can time charging to suit their own individual energy needs.
TP-Link PB50 - power bank - Li-pol
Power bank
13.97 cm x 7.89 cm x 1.93 cm
281.3 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Lithium polymer - 10000 mAh
Cables
Micro-USB cable
Power bank
13.97 cm
7.89 cm
1.93 cm
281.3 g
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2 A
LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, overdischarging protection
Lithium polymer
10000 mAh
Max Recharge Cycles
500
Carrying pouch
Micro-USB cable
BRPL C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
BRPL C2G 5m USB 2.0 A/B Cable - Black In Stock £4.54
BRPL C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.63
BRPL C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
BRPL C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.57
BRPL C2G USB 2.0 To Fast Ethernet Adapter In Stock £21.06
BRPL C2G USB Superbooster Extender Kit In Stock £37.45
BRPL C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.15
BRPL C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
