TP LINK OC200 Omada Cloud Controller
Quicklinx: FCMMWS00 Mfr#: OC200
25 in stock
£40.74 ex VAT
£48.88 inc VAT
The OC200 Omada Cloud Controller delicate to provide centralized management for the whole Omada network. Monitor statistics in real-time, view a graphical analysis of network traffic, create a captive portal, upgrade and reboot your system, and easily scale your network to boost your business.
  • Advanced hardware design
    Equipped with an advanced hardware design and the latest chipset, OC200 has the impressive processing power to support the massive management of your business network.
  • Guest network with Facebook Wi-Fi and SMS login
    Visitors have access to secure Wi-Fi with captive portal and wireless isolation technology. The SMS authentication simplifies the connection process, while Facebook authentication raises the social media profile of your business.
TP-Link Omada Cloud Controller OC200 - network management device
Network management device
Desktop
Ethernet, Fast Ethernet
Manageable access points: 100
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE
10 cm x 9.8 cm x 2.5 cm
10 cm
9.8 cm
2.5 cm
Desktop
Wired
Status Indicators
Power, cloud
Load balancing, VLAN support, Quality of Service (QoS), Multiple SSID support, reset button, beamforming technology, band steering, rate limit, Airtime Fairness, layer 3 management
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
IEEE 802.3af, IEEE 802.3at
1 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 1 x USB 2.0 - Type A , 1 x micro-USB (power only)
1 x network cable
FCC, RoHS
PoE
5 Watt
10 - 90% (non-condensing)
Brand: TP LINK
Price Range Ex VAT: 0 - 50
