TP-LINK's NC200 cloud camera is a cloud-based Wi-Fi video monitoring device with free live streaming and remote viewing that makes it easy to stay connected with whatever you care about most in your home or business, wherever you are.
Anywhere, Anytime Access with the tpCamera App
With tpCamera App installed on your smartphone or tablet, you can access your cameras anywhere there is Internet access, whether you are on a vacation or on the way, you always have a real time view of your home or business.
Alert for Invasions
Get instant notifications by email and immediately know what is happening. You can capture the images and record the movements of intruders, to help the police bring bad guys into custody.
Expand Your Existing Wi-Fi
The TP-LINK NC200 cloud camera also acts as a wireless extender, which means that you will have additional wireless coverage around each camera that you deploy.
Easy Installation
Simply run the wizard on your laptop or download the exclusive tpCamera App on your iPhone, iPad or Android devices, then you can enjoy the benefit of being connected to what matters most to you anytime and anywhere.
Flexible Placement
With its compact design and wireless connectivity, simply choose the area you wish to monitor and set your camera up; anywhere, like your desktop, cabinet or near the ceiling.
Stay connected and secure
TP-LINK’s NC200 is your perfect home and office companion, to help you keep in touch with what matters most, providing you with that sense of well-being while you are at work or play. -
Stay alert with motion detection and instant email
The NC200 can be set up to send immediate notifications by email whenever motion is detected automatically, allowing you to remain aware of whatever's happening on the ground, giving you great peace of mind. -
Setup in minutes
The setup is so simple and user-friendly, that anyone can install and operate the camera within minutes, and WPS support means that if you have a router with WPS button, you can complete the setup wirelessly. -
Adaptable placement
You can place your NC200 anywhere you want, on the table, the wall, or even on the ceiling. -
High-speed wireless for fluid video and Wi-Fi expansion
With a stable high-speed Wi-Fi connection, you can enjoy fluid video streaming with ease. In addition, the NC200 can also expand your Wi-Fi network with its Wi-Fi Extender functionality.
- TP-Link NC200 Cloud Camera - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in microphone
- 6.1 cm x 2.4 cm x 9.6 cm
- Connectivity Technology
- Wired, wireless
- Camera
- Max Resolution
- 640 x 480
- Frame Rate (max)
- 20 frames per second
- Motion Detection
- Optical Sensor Type
- CMOS - 1/4" - 0.3 MP
- Minimum Illumination
- 0.5 lux
- Focal Length
- 3.85 mm
- Lens Iris
- F/2.8
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - network cable - external
- Voltage
- DC 9 V
- Date/time stamp, saturation control, brightness control, contrast control, image flip, image mirror, Motion Detection Technology, Wi-Fi Protected Setup (WPS), text stamp, notification picture to E-mail, notification picture to FTP
- Environmental Parameters (operating)
- 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 6.1 cm
- 2.4 cm
- 9.6 cm
Camera
- Colour - fixed
- Digital Video Format
- MJPEG
- Max Digital Video Resolution
- 640 x 480
- Motion Detection
- Digital Zoom
- 4
- 0.5 lux
- Digital Video Capture Resolution
- 640 x 480, 320 x 240
- Frame Rate (max)
Image Sensor
- 0.3 MP CMOS 1/4"
Lens Construction
- Focal Length
- 3.85 mm
- Lens Iris
- F/2.8
- Network Interface
- Network Protocols
- DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, HTTPS, UPnP, Bonjour, PPPoE, Samba
- Ports
- LAN - RJ-45
- Cables Included
- 1 x network cable - external
- FCC, RoHS
- Power Requirements
- DC 9 V
- Power Device
- Power adapter - external
- OS Required
- Apple MacOS X 10.7 or later, Microsoft Windows Vista / XP / 7 / 8
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
