TP LINK LB130 Smart Wi-Fi LED E27 (with B22 convertor) Bulb with Colour Changing Hue
Quicklinx: CNZMWS00 Mfr#: LB130
Type: Light bulb
Compatible With: Alexa
Stock Status: Clearance
£20.83 ex VAT
£24.99 inc VAT
Express delivery Order within the next 18 hours for delivery on Monday
Control your lighting from anywhere with the LB130. The smart bulb installs as easily as a standard light bulb, and connects to your home Wi-Fi in no time through the free Kasa app. Kasa lets you manage your lights with your smartphone or tablet, including adjusting brightness, setting schedules and scenes, and tracking energy used. The LB130 can also change colour, with more than 16 million hues available to match any mood or occasion. For added convenience, you can control the LB130 with your voice when paired with amazon Alexa.
Highlights:
* No Hub Required – Connect the bulb directly to your Wi-Fi at home
* Manage Remotely – Control your lights from anywhere with your tablet or smartphone the free Kasa app (iOS, Android)
* Colour Changing Hue – Fine-tune up to 16 million colours and adjust brightness as well as light appearance from soft white (2700k) to daylight (9000k)
* Voice Control – Pair to Amazon Alexa and to enable voice control
* Circadian Mode – Dynamically adjust light intensity and temperature to mimic natural light patterns
Package Contents:
* Smart Wi-Fi LED Bulb LB130
* Quick Installation Guide
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
  • Control from anywhere
    Connect the LB130 to your home Wi-Fi network and control it directly from anywhere.
  • Color changing hue
    With up to 16 million colors and adjustable brightness, the LB130 offers even more lighting possibilities to suit your aesthetic, your environment and your mood for various occasions. You can go wild with your imagination!
  • Enjoy peace of mind
    Schedule the LB130 smart bulbs around your life and have them to turn on, off, and adjust their light appearance to suit your preference. They can even adjust automatically to changing sunset and sunrise times so it comes on when it gets dark and turns off as the sun comes up.
  • Customize and set scenes
    Change the color and intensity as you wish, navigate the tunable white light from warm to cool until you feel comfortable. Smart Wi-Fi bulbs can be controlled separately or as a group, and your favorite settings can be saved as scenes.
  • Wake up with sunrise
    Circadian mode automatically matches light appearance to the time of day by adjusting brightness and warmth as the sun rises and sets. Wake up refreshed and fall asleep easily with natural lighting.
  • Away mode
    Improve your home security when you're not there by turning your lights on and off at different times, giving the appearance that you're home.
TP-Link LB130 - LED light bulb
Light Bulb Type
LED light bulb
Bulb Finish
Frosted
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
Colour Temperature
2700-9000 K
Luminous Power
800 lumens
Dimmable
Light Bulb
LED light bulb
Bulb Finish
Frosted
Wattage Equivalent
60 W
A+
16 million colours
Colour Temperature
2700-9000 K
Luminous Power
800 lumens
Dimmable
Android compatible, iOS compatible, Circadian mode, voice control, controlled via Wi-Fi
Internet of Things (IoT)
Intelligent Assistant Compatible
Alexa
175 g
Resources
The following resources are available for the TP LINK LB130 Smart Wi-Fi LED E27 (with B22 convertor) Bulb with Colour Changing Hue
Type: Light bulb
Brand: TP LINK
Price Range Ex VAT: 0 - 50
