TP LINK LB100 Smart WiFi LED Bulb with Dimmable Light (E27+Bayonet)
Quicklinx: D9YLWS00 Mfr#: LB100
Type: Light bulb
Compatible With: Alexa
Stock Status: Clearance
£18.40 ex VAT
£22.08 inc VAT
Express delivery Delivered on Tuesday
Light. Your Way.
LB100 - Smart Wi-Fi LED Bulb with Dimmable Light
No Hub Required – Connect the bulb to your Wi-Fi at home
Manage Remotely – Easy setup and control from anywhere with the free Kasa app (iOS, Android)
Dimmable Light – Dimming flexible white light for customized lighting
Voice Control – Pair to Amazon Alexa and the Google Assistant to enable voice control
Save Energy – Save energy without sacrificing brightness or quality
Compatibility – Compatible with Android, iOS and Amazon Alexa and the Google Assistant
Control from Anywhere
Using Wi-Fi, you can control the LB100 without a hub or additional hardware. Just open the Kasa app on your smartphone to manage the smart bulb remotely, anytime and anywhere.
Compatible with Android, iOS, Amazon Alexa and the Google Assistant
The Kasa app works with Android (4.1 and higher) and iOS (iOS 8 and higher) devices so you can control your home right from your smartphone or tablet. You can also use Kasa app to pair TP-Link smart home products with any Amazon Echo, Dot, Tap and the Google Assistant for voice control, giving you the ability to control your home with voice commands.
Save Energy with LED Bulb
The LB100 saves energy without sacrificing brightness or quality, and lasts up to 13.7 years.
Estimated energy cost:
Standard 50W Incandescent Bulb: £6.02 per year
TP-LINK LB100 Smart Wi-Fi LED Bulb (50W equiv.): £0.84
Schedule Your Light
Set schedules to turn on/off the Smart Bulbs at any chosen time for your convenience. For example, you can set the bulbs to turn on every morning to wake you up or every dusk to light up your room automatically.
Set the Scene. Any Scene
Save your light settings as different scenes to enjoy instant access to them. Smart Wi-Fi bulbs can be controlled individually or as a group, letting you set the ideal mood for your lifestyle and preferences.
Reading scene - Create lighting that calms and helps you see clearly.
Movie scene - Lower the lights to immerse yourself in a film.
Good Night scene - Turn off all your lights, or keep a few on for moving easily in the night.
IFTTT
IFTTT is a free platform that helps you do more with all your apps and devices. Kasa by TP-Link is a leading smart home system that includes Kasa Smart Plugs, Smart Bulbs, Smart Switches and more. It works with other leading smart home products such as Amazon Echo, Google Home, and more. Now with IFTTT, you can also create personalized Applets that trigger automatic actions on your Kasa devices.
Our favourite TPLink Kasa Applet: Turn on your lights at sunset
Turn on your light within 15 minutes of the sunset at your location - by TP-Link Kasa - https://ifttt.com/applets/fjksUhKu-turn-on-your-light-at-sunset
See all TPLink Applets on IFTTT here: https://ifttt.com/kasa
  • Fine-tune your lighting
    The LB100 has 600 lumens brightness with dimmable white light, which can provide you stable and customized lighting.
  • Save energy with LED bulb
    The LB100 saves energy without sacrificing brightness or quality.
  • Schedule your light
    Set schedules to turn on/off the smart bulbs at any chosen time for your convenience. For example, you can set the bulbs to turn on every morning to wake you up or every dusk to light up your room automatically.
  • Set the scene, any scene
TP-LINK LB100 - LED light bulb
Light Bulb Type
LED light bulb
Socket Type
E27 (also includes B22 Bayonet Adaptor)
Wattage
8 W
Wattage Equivalent
50 W
Colour Temperature
2700 K
Luminous Power
600 lumens
Beam Angle
270 degree(s)
Dimmable
AC 108 - 132 V
Light Bulb
LED light bulb
Socket Type
E27 (Also includes B22 Bayonet Adaptor)
Wattage
8 W
Wattage Equivalent
50 W
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
600 lumens
Beam Angle
270 degree(s)
Dimmable
Android compatible, iOS compatible, controlled via Wi-Fi
Power Requirements
AC 108 - 132 V
Internet of Things (IoT)
Platform
Kasa
Intelligent Assistant Compatible
Alexa
UL, FCC, RoHS
105 g
-20 °C
Type: Light bulb
Brand: TP LINK
Price Range Ex VAT: 0 - 50
