TP LINK KP105 Kasa Slim Smart Socket
Quicklinx: FMZ5WS00 Mfr#: KP105
Type: Smart plug
Compatible With: Alexa, Bixby
More than 50 In Stock
£12.49 ex VAT
£14.98 inc VAT
Control from Anywhere
Remotely control your connected devices on your smartphone.
Compact Design
Fits into sockets without blocking adjacent ones.
Voice Control
Free up your hands with simple voice commands. Works with Alexa, Google Home, and Bixby.
Schedule and Timer
Set a schedule or timer to switch your devices on or off automatically.
Multiple Safety Guarantees
Overheating protection and PC flame retardant material help minimize burning hazards. A sliding safety cover protects children from electric shock.
  • Hands-free voice control
    Connect your smart plug with Amazon Alexa, Google Assistant, and SmartThings, and control connected devices by only using your voice.
  • Simple to set up and use with Alexa
    Setup is faster than ever before with Alexa. Use your Echo device to set up the plug via voice command.
  • Remote access
    Control devices connected to the smart plug wherever you have internet using the free Kasa app on your smartphone.
  • Scheduling
    Set schedules with the Kasa Smart app to automatically turn your smart plug on or off while you're away.
  • Easy setup
    Download the Kasa Smart app and follow the setup instructions for your plug.
Kasa Smart KP105 V1 - smart plug - 802.11b/g/n
Smart plug
Functions
Turn electronics on/off
Internet of Things (IoT) Platform
Google Home, SmartThings
Intelligent Assistant
Alexa, Bixby
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
5.15 cm x 3.75 cm x 7.25 cm
Smart plug
Functions
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Android 5.0 or later, Apple iOS 10 or later
Power input
Child protection, voice control, overheat protection, flame-retardant, up to 13 A
Platform
Alexa, Bixby
Product Material
Polycarbonate
Nominal Voltage
AC 100 - 240 V
Warranty
RoHS
5.15 cm
3.75 cm
7.25 cm
90 g
5 - 90% (non-condensing)
Type: Smart plug
Compatible With: Bixby
Brand: TP LINK
