TP LINK KL430 Multicolour Kasa Smart Light Strip - 2m
Quicklinx: G4YNWS00 Mfr#: KL430
Type: Light strip
Compatible With: Alexa
Hurry, only 2 left in stock!
£41.66 ex VAT
£49.99 inc VAT
Express delivery Order within the next 2 hours for delivery tomorrow
Create an immersive or fun ambiance to your home with rich color patterns and brilliant lighting effects.
  • Endless lighting effects
    Pick from dozens of animated lighting effects from soothing "Raindrop" to the dazzling "Rainbow".
  • Scenes
    Bring an immersive or fun ambiance to your movie night. Create your own scenes however you wish.
  • Easy setup
    Stick, plug in and connect. The flexibility to bend, cut and extend allows you to add them to the exact place you desire.
  • Grouping
    Combine your light strip with other Kasa Smart devices for seamless control with a single tap on your smartphone.
  • Voice control
    Use simple voice commands to control your light strip with Alexa or Google Assistant.
TP-Link Kasa Smart KL430 - light strip - LED - 17 W - multicolour light - 2500-9000 K
Light strip
Light Source Type
LED
Wattage
17 W
Light Bulb Energy Efficiency Class
A
Colour of Illumination
Multicolour light
Colour Temperature
2500-9000 K
Intelligent Assistant
Alexa
Platform
Google Home
AC 120 V
Frequency Required
60 Hz
Light strip
Not Compatible Light Bulb Energy Class
B, C, D, E
Extendable, flexible, Wi-Fi controlled, 16 colour zones
Light Source
LED
Built-in LED Lamp
Wattage
17 W
A
Built-in LED Energy Efficiency Class Range
A, A++, A+
Multicolour light
Colour Temperature
2500-9000 K
Lifetime
25000 hours
Android compatible, iOS compatible, voice control
Power Requirements
AC 120 V
Frequency Required
60 Hz
Internet of Things (IoT)
Hub
Not needed
Platform
Google Home
Alexa
Power adapter, smart light strip controller
UL, FCC
Warranty
2 years
Length
2 m
78 g
-20 °C
G4YN TP LINK KL430E Multicolour Kasa Smart Light Strip - 1m extension In Stock £12.49
Type: Light strip
Brand: TP LINK
Stock Status: In stock
