TP LINK KL130B Multicolour Kasa Smart Bulb - Bayonet
Quicklinx: F8KYWS00 Mfr#: KL130B
Type: Light bulb
Compatible With: Alexa, Cortana, Google Assistant
£16.66 ex VAT
£19.99 inc VAT
Kasa Smart Light Bulb, Multicolor
Multicolor
With a wide range of colors and dimming capabilities, Kasa Smart’s multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
No Hub Required
Kasa Smart’s multicolor light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere
Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
Voice Control
Use simple voice commands to control your Kasa Smart multicolor light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Have your voice assistant change the color to help you wake up in the morning or adjust the brightness to help your kids settle down in the evening.
Auto White
Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules
Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
Energy Consumption Class A+
Kasa Smart's multicolor light bulb is certified to drive down energy consumption without losing quality.
  • No hub required
    Kasa Smart's multicolor light bulb connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Control from anywhere
  • Auto white
  • Scenes and schedules
    Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
TP-Link Kasa Smart KL130B - LED light bulb
Light Bulb Type
LED light bulb
Shape
A60
Socket Type
B22
Wattage
10 W
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
Multicolour light
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
230 degree(s)
Dimmable
AC 220 - 240 V
Frequency Required
50/60 Hz
Warranty
2 year warranty
Light Bulb
LED light bulb
Shape
A60
Socket Type
B22
Wattage
10 W
Wattage Equivalent
60 W
A+
Multicolour light
Colour Temperature
2500-9000 K
Luminous Power
800 lumens
Beam Angle
230 degree(s)
Dimmable
Colour changing LED, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Internet of Things (IoT) Hub
Not needed
Platform
Kasa
Communications Type
Cloud
Communications Technology
Wi-Fi
Intelligent Assistant Compatible
Cortana, Google Assistant, Alexa
RoHS, SAA, RCM, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
121 mm
Diameter
60 mm
138 g
-15 °C
Type: Light bulb
Compatible With: Cortana
Brand: TP LINK
