TP LINK KL120 Smart Light Bulb Tuneable
Quicklinx: F2Q8WS00 Mfr#: KL120
Type: Light bulb
Compatible With: Alexa, Cortana, Google Assistant
£20.83 ex VAT
£24.99 inc VAT
Express delivery Order within the next 12 hours for delivery on Monday
Kasa Smart Light Bulb, Tuneable
Tunable White – Create cozy warm whites to relax after a long day or energetic bright whites when you need a boost with Kasa Smart’s tunable white LED light bulb. Tune the appearance from a soft white (2700k) to a bright light (6500K).
No Hub Required – Kasa Smart’s tunable white LED light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Turn your light bulb on if it’s getting late so you’ll arrive to a well-lit home.
Voice Control - Use simple voice commands to control Kasa Smart’s tunable white LED light bulb with any Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to turn the bulb on and off or set schedules so it turns on when you wake up or to a soft white when you want to relax.
Auto White – Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them at your fingertips.
Energy Consumption Class A+ – The light bulb reduces consumption without losing brightness or quality, while saving you money.
Set and Enjoy
Match natural light patterns with your Kasa Smart tunable white LED light bulb.
Tunable White
Set your lights to a soft glow in the morning or tune them to full brightness at night with Kasa Smart’s tunable white LED light bulb. Control from the Kasa Smart app or use simple voice commands with Alexa, Google Assistant, or Microsoft Cortana.
Schedules
Scenes
You like your light bright while they like it dim — but you both hate adjusting every bulb each time. Solve both problems with Kasa Smart. Create multiple scenes with different settings and tap yours when you want the light your way.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Smarter Home with More Partners
Partnerships with IFTTT and Nest make your smart home more connected.
  • Tunable white
    Create cozy warm whites to relax after a long day or energetic bright whites when you need a boost with Kasa Smart's tunable white LED light bulb. Tune the appearance from a soft white to a bright light.
  • No hub required
    Kasa Smart's tunable white LED light bulb connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Control from anywhere
    Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Turn your light bulb on if it's getting late so you'll arrive to a well-lit home.
  • Voice control
    Use simple voice commands to control Kasa Smart's tunable white LED light bulb with any Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to turn the bulb on and off or set schedules so it turns on when you wake up or to a soft white when you want to relax.
  • Auto white
  • Scenes and schedules
    Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you're home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them at your fingertips.
  • Energy efficient
    The Title 20 and Energy Star certified light bulb reduces consumption without losing brightness or quality, while saving you money.
TP-Link KL120 - LED light bulb
Light Bulb Type
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10 W
Wattage Equivalent
60 W
Colour of Illumination
Soft white/daylight
Colour Temperature
2700/5000 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
AC 120 V
Frequency Required
50/60 Hz
Light Bulb
LED light bulb
Shape
A19
Socket Type
E26
Wattage
10 W
Wattage Equivalent
60 W
Soft white/daylight
Colour Temperature
2700/5000 K
Luminous Power
800 lumens
Beam Angle
220 degree(s)
Dimmable
Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled
Power Requirements
AC 120 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Internet of Things (IoT) Hub
Not needed
Platform
Kasa
Communications Technology
Wi-Fi
Intelligent Assistant Compatible
Cortana, Google Assistant, Alexa
Compatible Services
IFTTT
UL, FCC, CEC, DOE, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Warranty
3 years
118 mm
Diameter
60 mm
134 g
-15 °C
Type: Light bulb
Compatible With: Cortana
Brand: TP LINK
Price Range Ex VAT: 0 - 50
