TP LINK KL110B Dimmable Kasa Smart Bulb - Bayonet
Quicklinx: F8KWWS00 Mfr#: KL110B
Type: Light bulb
Compatible With: Alexa, Cortana, Google Assistant
23 in stock
£12.49 ex VAT
£14.98 inc VAT
Express delivery Order within the next 7 hours for delivery on Monday
Kasa Smart Light Bulb, Dimmable
Dimmable
Kasa Smart’s dimmable light bulb has a dimming range from 1% to 100%. Set the right brightness for any mood or activity. Turn your bulb to full brightness to get your kids up in the morning or dim it enough for them to fall asleep at night.
No Hub Required
The Kasa Smart Wi-Fi Light Bulb, Dimmable connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere
Control your smart light bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Smoothly dim the brightness of your light bulb from anywhere with the app.
Voice Control
Use simple voice commands to control your Kasa Smart dimmable light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Scenes and Schedules
Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Dim all your lights and set the scene for a romantic dinner or a movie night.
Energy Consumption Class A+
Kasa Smart's dimmable light bulb is certified to drive down energy consumption without losing quality.
  • No hub required
    The Kasa Smart Wi-Fi light bulb, dimmable connects to your home's secure Wi-Fi network. No need for a hub or extra equipment.
  • Energy efficient
    Kasa Smart's dimmable light bulb is drives down energy consumption without losing quality.
TP-Link Kasa Smart KL110B - LED light bulb
Light Bulb Type
LED light bulb
Shape
A60
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
Light Bulb Energy Efficiency Class
A+
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
230 degree(s)
Dimmable
AC 220 - 240 V
Frequency Required
50/60 Hz
Warranty
2 year warranty
Light Bulb
LED light bulb
Shape
A60
Socket Type
E27
Wattage
10 W
Wattage Equivalent
60 W
A+
Colour Temperature
2700 K
Luminous Power
800 lumens
Beam Angle
230 degree(s)
Dimmable
1%-100% dimmable, Android compatible, iOS compatible, voice control, controlled via Wi-Fi, remote controlled, tunable white
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Platform
Kasa
Communications Type
Cloud
Communications Technology
Wi-Fi
Intelligent Assistant Compatible
Cortana, Google Assistant, Alexa
Adapter
RoHS, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
121 mm
Diameter
60 mm
0.138 kg
88 mm x 72 mm x 150 mm
-15 °C
Type: Light bulb
Compatible With: Cortana
Brand: TP LINK
Price Range Ex VAT: 0 - 50
