Brand
TP LINK KC120 Kasa Smart Cam
Quicklinx: DXMPWS00 Mfr#: KC120
Protect your home and keep watch over those you care about most. Kasa cam is designed to deliver clear 1080p video the moment you start streaming, keeping you connected to your home anywhere you go.
Crystal Clear Video – Sharp and clear, wide-angle 1080p video makes sure you never miss a thing. Manually zoom in to get a closer look to what's going on. Even at night, the camera will detect activity 25 ft. (7.6 meters) away with Night Vision.
2-Way Audio – Communicate clearly with whoever you see on camera. Whether it’s your kids sneaking a cookie before dinner or your pets laying on the sofa, use 2-way audio to remind them to make better choices.
Easy Setup – Get the best angle and video from your Kasa Cam with an easy to adjust camera stand. Place it on a flat surface and start monitoring or use the magnetic base to affix it to your fridge.
Instant Notifications – With motion and sound detection, the Kasa Smart app alerts you of activity that matters and sends notifications straight to your smartphone.
Watch from Anywhere – Watch live or recorded video at any time on your smartphone with the free Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV or Google Chromecast.
Ready for Anything
You never want anything to happen to your home, but on the rare chance it does, Kasa Cam is ready to capture it.
Feel Like You’re There
Sharp and clear, wide-angle 1080p video makes sure you never miss a thing. Manually zoom in to get a closer look to what’s going on. Even at night, the camera will detect activity 25 ft. away with Night Vision.
See something special happening? Turn on the live stream and manually record what is happening.
Control with Your Voice
Kasa Cam makes it easy to keep an eye on your family with instant notifications and motion and audio detection. Control what alerts you receive by creating up to 4 custom activity zones, at no charge, around areas that are important to you.
Protect Every Pixel
We know your privacy is important to you, which is why every bit of your video is protected with industry-standard 128 bit AES encryption with SSL/TLS.
  • Ready for anything
    You never want anything to happen to your home, but on the rare chance something does happen, Kasa cam is ready. It's plugged in and always ready to capture video just in case something happens.
  • Feel like you're there
    Not all 1080p cameras are the same. Kasa cam is fine-tuned to deliver rich colors, balanced lighting and sharp video quality. Plus, it uses night vision to make sure you can monitor your home around the clock.
  • Control with your voice
    Kasa cam pairs with Echo Show, so you can use your voice to control it even when your hands are full.
  • Personalized smart home security camera
    Kasa cam makes it easy to keep an eye on your family with instant notifications and motion and audio detection. You can customize your Kasa experience with activity zones to only send alerts, that matter the most to you.
  • Protect every pixel
    Every bit of your video is protected with industry-standard 128-bit AES encryption with SSL/TLS.
TP-Link KC120 Kasa Cam - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
7.9 cm x 7.9 cm x 13.673 cm
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720p
Optical Sensor Type
1/2.7"
Focal Length
3.21 mm
Lens Iris
F/2.0
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Intelligent Assistant
Google Assistant, Alexa
1 - USB cable - external - 3.05 m
Voltage
DC 5 V
Digital image rotation, Motion Detection Technology, Push Notification, LED indicator, reset button, Audio Detection, activity detection, wireless encryption, WPA, WPA2-PSK, WEP
Environmental Parameters (operating)
0 °C - 40 °C; 10 - 95% (non-condensing) relative humidity
Warranty
2 year warranty
Audio Support
Wireless
7.9 cm
7.9 cm
13.673 cm
Camera
Colour - Day&Night - fixed - indoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
720p
Infrared Distance
7.62 m
Video Capture
1920 x 1080 @ 30 fps
Image Sensor
1/2.7"
Lens Construction
Focal Length
3.21 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
130
Network Interface
Network Protocols
TLS, SSL
Ports
USB - Micro-USB Type B
Mounting bracket, screw kit, stand with magnetic base
1 x USB cable - external - 3.05 m
IC, FCC, AES, RoHS
Power Requirements
DC 5 V
Power adapter - external AC 120/230 V (50/60 Hz)
Software Included
Kasa Care
Android 4.4 (KitKat) or later, Apple iOS 9 or later
Internet of Things (IoT)
Communications Type
Cloud
Communications Technology
Wi-Fi
Intelligent Assistant Compatible
Relative Humidity (operating)
