TP LINK KC100 Kasa Smart Spot Full HD Camera
Quicklinx: FCQYWS00 Mfr#: KC100
Kasa Spot - KC100
Keep an eye on your things with Kasa Smart Spot, an HD indoor security camera.
Crystal Clear Video
Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
Wide Angle Field Of View
The Spot's 130°, wide-angle field of view makes sure nothing is out of view. Set it up in a corner and get a full view of your living room or place it on top of a shelf to get a great view of your kitchen.
Instant Activity Alerts
No need to check your Kasa Spot throughout the day. Get automatic alerts when your Spot detects motion or sound.
Night Vision
Even in the dark, the Kasa Spot has Night Vision up to 20 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
Two-way Audio
Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
Activity Zones
Configure up to 4 customizable zones for more meaningful alerts at no cost to you. Place zones around your front door, kitchen or anywhere you like to focus your camera’s view.
24/7 Live View
Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
  • Motion snapshots
    Kasa Smart Spot will send you an alert when motion is detected and save the activity as a snapshot.
  • Clear video
    HD, wide-angle video and night vision, make sure you never miss a thing day or night.
  • Activity zones
    Create multiple activity zones around areas that are important and receive alerts you care about.
  • Two-way talk
    Communicate with others with the built-in microphone and speaker.
Kasa Smart Spot - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.89 cm x 4.95 cm x 8.86 cm
68 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa ready, Google Assistant ready
1 - USB cable - external - 3.05 m
Voltage
DC 5 V
Audio Detection, activity detection
Audio Support
Wireless
5.89 cm
4.95 cm
8.86 cm
68 g
Camera
Colour - Day&Night - fixed - indoor
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
6.1 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
Network Protocols
TLS, SSL
Template, screw kit
1 x USB cable - external - 3.05 m
Power Requirements
DC 5 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 (KitKat) or later, Apple iOS 10 or later
Internet of Things (IoT)
Shipping Width
16.45 cm
Shipping Depth
8.15 cm
Shipping Height
14.25 cm
