Brand
TP LINK Kasa Smart Home Starter Pack E27 - HS100, KL50, KL130, KC100
Quicklinx: FS5CWS00 Mfr#: KasaStarterPack-E27
Kasa Starter Pack - Includes HS100 Smart Plug, KL50 and KL130 Smart Bulbs and KC100 Spot Cam
HS100 Kasa Smart Wifi Plug
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
KL50 Kasa Filament Smart Bulb, Soft White
Control from Anywhere – Control your LED filament smart bulb from anywhere with your smartphone using the Kasa Smart app (iOS, Android). Turn your lights on and off from the office, check in and make sure you turned off your kitchen lights, even schedule lights to turn on before you get home.
Soft White – Kasa Filament Smart Bulb, Soft White’s 2700K temperature works well for any environment. Dim your light to any level of brightness for the right ambiance for a multitude of occasions. The dimmer the bulb, the more you can see the filament design inside.
Dimmable – Kasa Smart’s LED filament bulb has an expansive dimming range that can be controlled conveniently with the Kasa Smart app. Turn your filament bulb to full brightness for a well-lit vanity or dim it down for a dinner party.
No Hub Required – The Kasa Filament Smart Bulb, Soft White connects directly to your home’s secure WiFi network. No need for a hub or extra equipment. All you need is your smartphone, the Kasa Smart app and a WiFi connection to start remotely controlling your smart bulb.
Device Grouping – Use Grouping to combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap of your smartphone. Put all of your Kasa Smart light bulbs into a single group and dim them all at once for the perfect ambiance.
Voice Control - Use simple voice commands to control your Kasa Filament Smart Bulb with any Alexa or Google Assistant. Just tell your voice assistant to dim your lights and set the perfect mood for movie night.
Energy Monitoring – Using the Kasa Smart app, you can check on your LED filament bulb from anywhere to see how much energy is being consumed. Turn it off remotely to stop any consumption.
Set Schedules – Use your Kasa Smart app to schedule your LED filament light bulb to turn on and off around your daily routine.
Quick and Easy – Be up and lit with your new smart bulb! It’s as easy as 1-2-3 or A-B-C! Screw your bulb in, follow the simple setup in the Kasa Smart app, name it and get to glowing.
Grouping – Combine your smart filament bulb with other Kasa Smart devices for seamless control with a single tap on your smartphone.
Smart Actions – Enable device interconnections and home automation for your Kasa devices. There are three types of Actions that can be created: "Motion Sensing", "Schedule a Scene" and "Auto-off Timer".
KL130 Kasa Smart Bulb, Multicolour
Multicolor – With a wide range of colors and dimming capabilities, Kasa Smart’s multicolor light bulb offers endless lighting possibilities. You can choose a light for everything from a dinner party to a late-night study session.
No Hub Required – Kasa Smart’s multicolor light bulb connects to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Control from Anywhere – Control your smart light bulb from anywhere with your smartphone using the free Kasa Smart app (iOS, Android). Dim, turn on or off or change the colors of your light bulb remotely at your fingertips.
Voice Control - Use simple voice commands to control your Kasa Smart multicolor light bulb with any Amazon Alexa, Google Assistant or Microsoft Cortana. Have your voice assistant change the color to help you wake up in the morning or adjust the brightness to help your kids settle down in the evening.
Auto White – Set your bulb to automatically adjust its color temperature to match natural light patterns from dawn to dusk.
Scenes and Schedules – Use your Kasa Smart app to schedule your light bulb to automatically switch on and off when you’re home or away. Combine all your lights with other Kasa Smart devices in a Scene and control them with a single button. Create a party scene and have your smart lights change to any color you want.
Energy Consumption Class A+ – Kasa Smart's multicolor light bulb is certified to drive down energy consumption without losing quality.
KC100 Kasa Spot Cam
Crystal Clear Video - Sharp and clear 1080p full-HD provides high-quality video right in the palm of your hand.
Wide Angle Field Of View - The Spot's 130°, wide-angle field of view makes sure nothing is out of view. Set it up in a corner and get a full view of your living room or place it on top of a shelf to get a great view of your kitchen.
Instant Activity Alerts - No need to check your Kasa Spot throughout the day. Get automatic alerts when your Spot detects motion or sound.
Night Vision - Even in the dark, the Kasa Spot has Night Vision up to 20 feet. Never miss a thing at night and still get the same high-quality video you’re used to.
Two-way Audio - Use crisp two-way audio to communicate with nosy roommates, family or even mischievous pets.
Activity Zones - Configure up to 4 customizable zones for more meaningful alerts at no cost to you. Place zones around your front door, kitchen or anywhere you like to focus your camera’s view.
24/7 Live View - Keep an eye on what’s important to you real-time from anywhere with the Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, like a Fire TV, Echo Show or Chromecast.
Cloud Storage – Supports secure cloud storage to review and download your recordings from Kasa app (additional charges apply).
  • Motion snapshots
    Kasa Smart Spot will send you an alert when motion is detected and save the activity as a snapshot.
  • Clear video
    HD, wide-angle video and night vision, make sure you never miss a thing day or night.
  • Activity zones
    Create multiple activity zones around areas that are important and receive alerts you care about.
  • Two-way talk
    Communicate with others with the built-in microphone and speaker.
Kasa Smart Spot - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.89 cm x 4.95 cm x 8.86 cm
68 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
15 frames per second
Motion Detection
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa ready, Google Assistant ready
1 - USB cable - external - 3.05 m
Voltage
DC 5 V
Audio Detection, activity detection
Audio Support
Wireless
5.89 cm
4.95 cm
8.86 cm
68 g
Camera
Colour - Day&Night - fixed - indoor
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
6.1 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Lens Construction
Horizontal Field of View (degree)
130
Network Interface
Network Protocols
TLS, SSL
Template, screw kit
1 x USB cable - external - 3.05 m
Power Requirements
DC 5 V - 1 A
Power adapter - external AC 120/230 V (50/60 Hz)
Android 4.4 (KitKat) or later, Apple iOS 10 or later
Internet of Things (IoT)
Shipping Width
16.45 cm
Shipping Depth
8.15 cm
Shipping Height
14.25 cm
