TP LINK HS100 V2.1 Smart Plug
Quicklinx: F31RWS00 Mfr#: HS100 V2.1
Type: Smart plug
Compatible With: Alexa, Google Assistant, Nest
More than 50 in stock
£12.49 ex VAT
£14.98 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
Manage Your Home Electronics and Appliances Anytime, Anywhere
The smart plug is easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Add an extra layer of security with Away Mode. Connected devices will randomly turn on and off throughout the day to make it look like you’re home.
Modern, Elegant, Simple
Inspired by a modern sensibility, the smart plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The smart plug gives you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Remote Access
Control devices connected to the Smart Plug wherever you have Internet using the free Kasa app on your smartphone.
Schedule
Away
Easy to Use and Install
Just connect the Smart Plugs to your Wi-Fi network and control using the free Kasa App on your smartphone.
Amazon Echo Voice Control
Amazon Echo (sold separately) lets you control devices connected to the Smart Plugs using just your voice.
  • Remote access
    Control devices connected to the smart plug wherever you have Internet using your smartphone.
  • Scheduling
    Schedule the smart plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
  • Energy monitoring
    Analyze a device's real-time and historical power consumption.
  • Away mode
TP-Link HS100 - smart plug
Smart plug
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
6.63 cm x 7.7 cm x 10.03 cm
Warranty
2 year warranty
Smart plug
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
iOS, Android
Power scheduling
Power Provided
3.68 kW
RoHS, EAC
6.63 cm
7.7 cm
10.03 cm
131.8 g
5 - 90% (non-condensing)
Type: Smart plug
Compatible With: Nest
Brand: TP LINK
Price Range Ex VAT: 0 - 50
