TP LINK HS100 Kit Kasa Smart Wifi Plug 2-Pack
Quicklinx: F0W6WS00 Mfr#: HS100 KIT V2.1
Type: Smart plug
Compatible With: Alexa, Google Assistant, SmartThings
Stock Status: In Stock, Used Stock
More than 50 in stock
£33.33 ex VAT
£39.99 inc VAT
Smart Control for A Smart Home
Manage Your Home Electronics and Appliances Anytime, Anywhere
The smart plug is easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Add an extra layer of security with Away Mode. Connected devices will randomly turn on and off throughout the day to make it look like you’re home.
Modern, Elegant, Simple
Inspired by a modern sensibility, the smart plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The smart plug gives you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
  • Remote access
    Control devices connected to the smart plug wherever you have Internet using your smartphone.
  • Scheduling
    Schedule the smart plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
  • Energy monitoring
    Analyze a device's real-time and historical power consumption.
  • Away mode
    Turns your devices on and off at different times to give the appearance that someone is home.
TP-Link HS100 - smart plug
Smart plug
Packaged Quantity
2 (specifications are for single item)
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android
United Kingdom
10.03 cm x 6.63 cm x 4.68 cm
Warranty
2 year warranty
Packaged Quantity
Smart plug
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 Ghz
Android 4.1 (Jelly Bean) or later, iOS 9 or later
Power scheduling
Internet of Things (IoT)
United Kingdom
Power Provided
3.12 kW
RoHS
10.03 cm
6.63 cm
4.68 cm
290 g
Shipping Width
18.6 cm
Shipping Depth
14 cm
Shipping Height
8.8 cm
Shipping Weight
460 g
10 - 90% (non-condensing)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F0W6 042468
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £22.55
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Smart plug
Compatible With: SmartThings
Brand: TP LINK
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
